Need help getting bike started! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 12-27-2013, 06:36 PM Thread Starter
Hey ya'll, my brother recently acquired an 05 Vulcan 750. He picked it up from a place that stored rebuilder bikes outside. It has 15,600 miles on it, plugs have been changed and the starter solenoid has been changed as far as important components for starting. I noticed that it wasn't getting any fuel. I took the tank off and applied vacuum to the port and no fuel came out. Then I tested to see if the vacuum line from the carb has vacuum which it does. I removed the fuel petcock and cleaned the screens but that didn't work either. My guess is that the fuel petcock is clogged or something else is happening that I am blind too. Your help would be greatly appreciated.
KVSevenfitty is offline
post #2 of 4 (permalink) Old 12-27-2013, 07:53 PM
Welcome to the family.check to see if it flows on the primary setting then try blowing back thru them first.the vacuum module might also be faulty
post #3 of 4 (permalink) Old 12-27-2013, 08:01 PM
If your subject line is correct, gravity feed the carbs from a small can of gas.
wmsonta is offline
post #4 of 4 (permalink) Old 12-27-2013, 10:04 PM
Take a look inside the tank and make sure there isn't a pound of rust and gunk sitting at the bottom blocking the fuel port. If the bike was stored outside there might be.
jj23 is offline
