Fuel line size - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-12-2007, 06:40 PM Thread Starter
Mushu's Avatar
Send a message via MSN to Mushu
Fuel line size
Does anyone know the size of the tubing for the fuel lines? Mine are a bit old and I want to replace them all...
Thanks for the help
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #2 of 9 (permalink) Old 06-12-2007, 06:54 PM
93VN750's Avatar
I think it is metric as I tried every SAE fuel line in the store and none were correct.
Let us know what you come up with.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 9 (permalink) Old 06-14-2007, 01:18 AM
racohoon's Avatar
Just replaced mine with 5/16" fuel line.
racohoon is offline
post #4 of 9 (permalink) Old 06-14-2007, 03:52 AM
yes i just bought 5/16'' inside diameter line for mine, BUT the stock lines had a slightly larger outside diameter, so i also bought some of those "line compressors" for that size
t_cel_t is offline
post #5 of 9 (permalink) Old 06-14-2007, 04:18 AM
I just used 1/4" fuel line from NAPA, but I have some carb probs, so maybe you shouldn't listen to me.
ragingbender is offline
post #6 of 9 (permalink) Old 06-14-2007, 11:00 AM Thread Starter
Mushu's Avatar
Thanks, I'll try to find 5/16" fuel line for the replacement.
93 VN750
Mushu is offline
post #7 of 9 (permalink) Old 07-23-2007, 01:13 PM
storm16's Avatar
Just for the record (I know this thread is old), I used 5/16" lines when I rebuilt the carbs. I agree with 93VN750 that it is probably metric, because on the second ride after replacing them, the lines started leaking like a sieve. I ended up getting some hose clamps from the auto parts store (the original lines didn't use them) and everything has been great ever since.
Storm16
Culpeper, VA
1985 VN700A1 "WindRider"
21,500 miles (9/07)
R/R relocate (9/07)
AGM Battery (10/07)
storm16 is offline
post #8 of 9 (permalink) Old 08-05-2007, 07:38 PM
Basketcase
Anyone ever figure out what size line to use? Going to be bringing an old bike back from the dead and want to change the lines as well.
newvn750owner is offline
post #9 of 9 (permalink) Old 08-05-2007, 09:10 PM
storm16's Avatar
I ended up using 5/16" line, but it was from an auto parts store. Worked fine, but after the second ride or so, it apparently expanded on the petcock side, because it started leaking. (Maybe metric petcock and SAE hose?) I used a hose clamp on the petcock ends and it was all good.
Storm16
Culpeper, VA
21,500 miles (9/07)
R/R relocate (9/07)
AGM Battery (10/07)
storm16 is offline
