Disconnecting throttle and choke cables? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 11-19-2013, 08:04 AM Thread Starter
Hey, back again with yet another stupid question. How do I disconnect the theottle and choke cables from the carburetor? I see that it's held in place with a circular "bracket" with a slot for the cable to come out. On the throttle cable, I have access to the "bracket" but not enough slack in the cable. On the choke cable, I DON'T have access to the bracket, but I DO have enough slack in the cable. I guess I'll just throw another problem out there too: when I turn the throttle, it sticks in place and I have to roll my hand forward for the throttle to release. Any way to remedy this?
MrBlondyable is offline
post #2 of 8 (permalink) Old 11-19-2013, 08:57 AM
Disconnect the cables at the bar ends...provides slack to disconnect at carbs.
Re-Lube the cables prior to carb installation.
Most any lube will work....except no WD-40 or such....oil is to thin for lube longevity .
WilliamTech
post #3 of 8 (permalink) Old 11-19-2013, 09:27 AM
You get slack in the throttle cables by screwing them all the way in first at the throttle handle. Then you can further slackin' down at the carb.
post #4 of 8 (permalink) Old 11-19-2013, 03:34 PM
Dr. Vulcanstein
jadabull's Avatar
This is a tip for after you reinstall the cables.....If your throttle is sticking and you have to roll your hand grip forward you have too much tension in the cable, loosen it with the adjuster.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 8 (permalink) Old 11-19-2013, 04:29 PM
Originally Posted by jadabull View Post
This is a tip for after you reinstall the cables.....If your throttle is sticking and you have to roll your hand grip forward you have too much play in the cable, tighten it down with the adjuster.
In my experience, the cables being too TIGHT are what bind the throttle sleeve. Someone please correct me if I am wrong here.
Too loose and you get slop at either end usually.
It could also be a bad or freyed cable hanging up in the sleeve.
post #6 of 8 (permalink) Old 11-19-2013, 07:44 PM
x2
post #7 of 8 (permalink) Old 11-20-2013, 01:08 AM
Dr. Vulcanstein
jadabull's Avatar
X3.........you're right Kc, my dyslexia was kicking in.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #8 of 8 (permalink) Old 11-20-2013, 11:04 AM
it's all good bro!!
I mis-type quite often myself......the brain and fingers sometimes don't sync and require a reboot...lol
