Octain Evaporation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 11-19-2013, 06:55 AM Thread Starter
Big Nick's Avatar
Octain Evaporation
So I read somewhere that Petrol evaporates it's octane, over about 35 deg celseus. So this temp is common under the fuel tank. Also the ambient temp in my town commonly in summer. My question is does anyone have an idea about a spray on insulation for under fuel tanks?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 2 (permalink) Old 11-19-2013, 08:03 AM
I can't see that being an issue at all for you...but if you wanted to do something on the bottom of the tank you have a few options. You could use truck bed liner (not great insulation) or you could go buy a sheet of adhesive backed aluminized foil and stick that under the tank. That would reflect heat back towards the engine.
Either way I don't think you'd see any significant change.
