rsavant - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 11-18-2013, 09:34 PM Thread Starter
rsavant's Avatar
rsavant
Hey guys, new to the forum. I recently purchased a 2002 VN750 after not riding for about thirty years. I'm really enjoying the bike. So here's my problem: at cruise speed, 55 to 60 mph, the engine will stumble a bit much like its running out of fuel. Opening the throttle a bit or adding slight choke and it runs fine again. I spent about 6 hrs removing and cleaning the carbs, which didn't seem very dirty. They'd been cleaned by the dealer before my purchase but the bike had been sitting for a while. While I think the bike runs better, it still has the stumbling problem. I've read about the POOG symptom and I'll try filling the tank and see what happens. Any ideas? Sorry for the lengthy post! Thanks.
rsavant is offline
post #2 of 23 (permalink) Old 11-18-2013, 10:08 PM
2000 VN 750 Senior Member
Try using some Seafoam in the fuel tank for a few fillups. Seafoam is the miracle fluid of this forum and cleans up those carbs and everything else.
Since you are new to the forum how about letting us know where you are from and possibly posting a few pictures of your bike. Also as you are returning after a considerable length of time away from two wheels let us know what you were riding before. There is a lot of experience here and any problem you may run into with the VN750 I am sure this forum will come up with a solution. I doubt if there is anything new about this particular bike that hasn't been dealt with by at least one of our members. Try the Seafoam and I am sure a more knowledgeable member will chime in very soon on other possible cures. Good luck and welcome.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #3 of 23 (permalink) Old 11-18-2013, 10:31 PM
Welcome to the forum brother! Good luck!
Tuvoc is offline
post #4 of 23 (permalink) Old 11-18-2013, 10:51 PM
Dr. Vulcanstein
jadabull's Avatar
X2 on the seafoam, might also want to check your plugs.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 23 (permalink) Old 11-19-2013, 06:09 AM
Tell us more about your bike. Is it stock or has it had modifications?
post #6 of 23 (permalink) Old 11-19-2013, 06:42 AM
Big Nick's Avatar
Air filter?
If it's got a foam air filter,you might try some light machine oil on the foam, helps with the vacuum. Supposed to clean and re oil them, from time to time.
Enjoy the ride.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #7 of 23 (permalink) Old 11-19-2013, 10:04 AM
this symptom sounds like the vcrb vent is not properly shielded from the "wind".
There are 2 vent lines from the carbs that go to a "T" connection and on a stock bike, they are routed to behind the right side air filter box.
There are SLOTTED holes on the back of the "EAR" or air filter box that the hose gets inserted into to protect it from airflow.
The hose should be cut on an angle so that it does not bottom out. The slits in the hole that the hose goes into allows it the vent without getting air pressure of vacuum from airflow at speeds.
If the bike is modified and the filter pods were removed and replaced by the "EAR SHAVE" mod, then the hose should be stuffed up under the tank or inside the frame someplace to shield it from wind.
post #8 of 23 (permalink) Old 11-19-2013, 09:36 PM Thread Starter
rsavant's Avatar
The bike is stock, no performance mods of any kind. It has a fuel starvation problem, I was able to prove this today by running it with the choke on. It ran smooth as could be with the choke and had practically no popping when the throttle was closed. Are the adjustments on the carbs more for low speed?
Thanks for the welcome and the help. I'm really glad I found the forum. Also, someone asked where I'm located. That would be middle Georgia.
rsavant is offline
post #9 of 23 (permalink) Old 11-19-2013, 09:48 PM
sounds like in need of a possible carb cleaning...maybe Seafoam will perform the need/improvement.
....others will/may give better/added advice.
post #10 of 23 (permalink) Old 11-20-2013, 07:16 AM Thread Starter
rsavant's Avatar
I'd tried Sea Foam and the problem persisted so with the help of a friend we pulled, disassembled, and cleaned the carbs, which seemed pretty much clean to begin with. I think the bike accelerates a little faster but the stumbling and popping seems a little worse. I'm thinking there is an air leak or something else going on since the problem now seems worse. It runs perfectly with the choke on at cruise speeds. Getting the carbs off and on is a pain! I'll get a shop manual before I do that again.
rsavant is offline
