Can't open gas tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 11-13-2013, 11:43 AM Thread Starter
Jocyne's Avatar
Can't open gas tank
Hey all! It's been a while since I've posted on here, I hope everyone is doing well.
And as usual, I always end up having weird issues. I went to open up my tank the other day and I wasn't able to, the key turned a little and then bent from the resistance. I was able to bend it back and put some WD40 in there and it still didn't work. I assumed it got a little corroded in there seeing how I live in Florida but I can't really figure out what to do...Any help would be appreciated!
And then of course, when I was able to bend my key back (it was BARELY bent) I now can't even start the bike(the ignition wont turn to start)...Even though the key is back to where it was originally. I have a spare key but the previous owner said it doesn't work, which he was correct. Anyway, any suggestions on that? Or do I need to call the dealership in hopes that they have a copy or can order me one?
Sorry for all the trouble! I'm eternally grateful for all the help you guys have provided me in the past.
-Jo
Jocyne is offline
post #2 of 11 (permalink) Old 11-13-2013, 12:15 PM
-Jo
Did you press down on the cap hard while turning? I can't open mine otherwise.
post #3 of 11 (permalink) Old 11-13-2013, 12:19 PM Thread Starter
Jocyne's Avatar
I sure did. :/
Jocyne is offline
post #4 of 11 (permalink) Old 11-13-2013, 12:33 PM
Well you can always knock the pin outta the hinge to get it open. Once you take it off you can see what's really going on with it. Either needs a good cleaning (bet that's it) or something is bent/worn enough to not work. As for your key I'm sure a local locksmith can cut u one if they have the blank. The stealership will be expensive for a key. If your spare is in good shape you could have both the gas cap and ign rekeyed to the spare.
post #5 of 11 (permalink) Old 11-13-2013, 02:58 PM Thread Starter
Jocyne's Avatar
I will definitely try that out and check into a local locksmith, if the key wont work again tonight. Thank you!!
Jocyne is offline
post #6 of 11 (permalink) Old 11-13-2013, 04:33 PM
R/R = Relocated Redneck
Jakzen's Avatar
I had problems with both spares i had cut. Picked up a set of mini files at harbor freight and massaged the keys until they worked. You could probably use a fingernail file if push came to shove.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #7 of 11 (permalink) Old 11-13-2013, 04:40 PM
200% senile
Texas's Avatar
The gas cap on the 96 I just recently bought would not open either. No way, no how, bent the key trying. I knew to push down hard on it while trying to open it but that wasn't working either.
My neighbor came over and I told him the problem. He slammed his fist down on top of the cap, put the key in and opened it right up.
Needless to say probably but once open, I lubed everything up and worked the mechanism until everything was moving freely before closing it again.
My son straightened the key back out and we have been good to go ever since.
1996 VN 750
2007 Vulcan Mean Streak SE
When I was younger I was afraid I'd die riding. Now that I'm old and falling apart, I'm afraid I won't.
Texas is offline
post #8 of 11 (permalink) Old 11-13-2013, 05:11 PM
As for re-keying. I had a lot of trouble finding a dealer who would cut me a key. But for them to do that, they'll need the numbers off of it. All the locksmiths in my area I found to be ridiculously priced. $85!
I got a key made from a dealer in New Philadelphia Ohio for about $12 & $5 for the key.
post #9 of 11 (permalink) Old 11-17-2013, 01:42 AM
I bought some rubber headed keys off eBay and went to the local locksmith w/ the gas cap and new keys and they where able todo it.
PS locksmith didn't carry blanks for Kawasaki's.
sn95bullitt is offline
post #10 of 11 (permalink) Old 11-18-2013, 07:05 PM
Chasin' the blacktop
Spencer1's Avatar
I had to buy a blank key off EBay and take it to my local locksmith to get it cut. total cost $9.
North Georgia
Spencer1 is offline
