air/fuel adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-26-2013, 05:46 PM Thread Starter
air/fuel adjustment
I have read several posts on the air/fuel adjustments for the carbs, my manual says 1 5/8 out, many have said 2 1/2 turns out is best....I assume these adjust the rich/lean of the carb? Reason I ask is Im at 5,000 elevation, would 2 1/2 turns be too rich, thats what I have mine at now but I notice the plugs are dark.....and the bike I assume has stock jetting. thanks.
RangerRick is offline
post #2 of 9 (permalink) Old 10-26-2013, 07:44 PM
2 1/2 turns out is base line for tuning a carb, from there you are fine to go one more full turn in or out.
post #3 of 9 (permalink) Old 10-26-2013, 10:17 PM
Hey slim exactly how do you tune a crab? Lol
post #4 of 9 (permalink) Old 10-27-2013, 12:25 AM
Okiebezer's Avatar
I've heard you can tune a piano AND you can tuna fish, but a crab??
Sorry, couldn't resist...
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #5 of 9 (permalink) Old 10-27-2013, 12:45 PM
gibbo's Avatar
These screws only alter the mixture at slow running, unless of course, you have very exotic crabs!
One can never have too many alternative forms of transport.
gibbo is offline
post #6 of 9 (permalink) Old 10-27-2013, 01:15 PM
Wink
Make sure no fuel is passing through the vacuum line off the petcock to the left carb.
Make sure the 'choke' plungers are closing all the way.
Coasting Enrichers could be stuck open.
Air filters are clean?
Crab? usually about a 1/4 turn, pull, dip in butter ... yum. Wipe the chin.
post #7 of 9 (permalink) Old 10-28-2013, 12:06 PM
The pilot air screws are active from 1-3 1/2 turns. Factory is 1 5/8 turns and most would consider it too lean.
This adjustment is mostly to adjust 'manners'. Pulling away from a stop, etc. You could run this adjustment too lean with out damage.
I adjust mine to where the bike will chug happily at idle in second gear at idle on level smooth pavement. If it can do that, you will not improve the neutral idle. I like mine to have excellent 'manners'. IE, a little too rich.
HTH.
wmsonta is offline
post #8 of 9 (permalink) Old 10-28-2013, 12:20 PM
You guys got me...
post #9 of 9 (permalink) Old 11-06-2013, 02:29 PM
Mine are at 2 1/2 turns out, at 1200 feet. It gets a bit rich at 9,000 feet when I ride up in the mountains, and will sometimes die at idle. It has a perfect 1000 rpm idle at 1200 feet with no misfiring. The tach needle looks dead still.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
