backfire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-27-2007, 05:22 PM Thread Starter
Send a message via AIM to b cameron
backfire
hi guys,
still got a problem with my VN750.
front cylinder not working. cleaned carbs, new battery, plugs, leads and caps.
just marbled it (no emissions over here), no exhaust leaks, plenty of compression.
but!..........lots of suction on rear carb, practically none on front(hand over open carb)
runs on two for a few seconds intermitently. starts straight away.
bike has been standing for two years, but ran fine till then. shortened exhaust by removing that big lump in the middle.
any ideas?
b cameron is offline
post #2 of 5 (permalink) Old 05-27-2007, 09:55 PM
HAWK
Ccspinner's Avatar
If you have no suction on the front cylender but you have compression then I would check the cam chain.
If the intake valves are not opening you wont get any suction but can have compression. You may have had the chain jump causing to be way out of time. But then you would not have good compression.
Do you have access to a borascope?
They are great to have to help find valve problems.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 5 (permalink) Old 05-28-2007, 12:35 PM Thread Starter
what is a borascope?
if the timing is out,how can i check. bike only has 8k from original on it.
could the valves be sticking.
every now and then it ticks over perfectly for a few seconds. wondering if the coil may be breaking down under load, or a fuel problem.
what do you think guys?
post #4 of 5 (permalink) Old 05-28-2007, 12:45 PM
HAWK
Ccspinner's Avatar
Borascope is a tool that allows you to look into the cylender throught the sparkplug hole. Has a light and a mirror on it, kinda like a small parascopeon a sub.
I have one at work, I am a mechanic though.
Chad Falstad "Hawk"
Vroc #17649
post #5 of 5 (permalink) Old 05-28-2007, 01:40 PM Thread Starter
Smile
ok, i will see if i can get hold of one.
cheers
Bambi
