can this be done??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-27-2007, 04:57 AM Thread Starter
can this be done???
I would like to remove the existing air filter housings and replace them with ones that would come directly off the carbs and be between the two cylinders like other bikes has anyone done this or know if it could be done??? Mike..
guynxdoor682000 is offline
post #2 of 11 (permalink) Old 05-27-2007, 11:45 AM
85 VN 700
curtis97322's Avatar
What you're wanting to do is called an ear shave 'round here. Search for it and you should be able to find some good info.
You need to be aware that with an ear shave you will need to rejet the carburators and your milage will go down - along with a slight performance increase. Many have had huge headaches trying to get the jetting right after an ear shave.
That said, it does look better and more performance is always good. It's one mod I might do in the future.
Welcome to the forum, check your splines, read the vulcan versus, etc.
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #3 of 11 (permalink) Old 05-27-2007, 02:30 PM
HERE is the post from the Vulcan Verses about the ear shave.
It includes a list of what's needed to do this.
post #4 of 11 (permalink) Old 10-14-2007, 01:12 AM
Look for the ear shave posts. Most of them also have pics and other good info to go with.
post #5 of 11 (permalink) Old 10-14-2007, 02:36 AM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
My VN750 is earshaved. I do not recommend it. The looks are better IMHO but you lose gas milage big time and it is perminant if you remove the surge tank. See pictures at http://www.bulldogsbike.com
Evan Breyn ~ The Bulldog
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 55,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #6 of 11 (permalink) Old 10-14-2007, 12:53 PM
Search Goddess
Dianna's Avatar
One thing... If you do an ear shave this is the one time you DO HAVE TO REJET your carbs.
Adjusting the air mix screws is not enough.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #7 of 11 (permalink) Old 10-14-2007, 12:57 PM
I did not rejet, what do I need to look for to know that I need to rejjet? My bike runs fine through all speed selections and the rpm's reve up good too.
post #8 of 11 (permalink) Old 10-14-2007, 01:13 PM
Search Goddess
Dianna's Avatar
the post that Hyper referenced has a parts list
https://www.vn750.com/forum/showthread.php?t=1102
You might want to check your plugs to see how you are running
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #9 of 11 (permalink) Old 10-14-2007, 01:31 PM
Thanx for the info, but my bike runs fine, I do not see any reason to rejet. Runs really good and the mileage is just under what it was before. I did adj. some on the needles. I think my missing problem was caused by the busted diaphram in the air valve under the seat, which is now gone when I coasterd.
post #10 of 11 (permalink) Old 10-15-2007, 07:15 PM
Sky Rider's Avatar
Read your plugs as you are probably running lean. Over time, this can damage the engine from heat though it won't show up on the temp gauge.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
