fuel inlet fitting broken - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-06-2013, 03:27 PM Thread Starter
bamaboy's Avatar
I'm not sure if I did it when I was removing the carbs to clean them, or if the bike came that way, I didn't think I was that rough taking them out. Bit the plastic elbow that the fuel inlet hose connects to was half gone and loose from the brass fitting that screws into the carb. I tried to gently unscrew the brass, but it's so tight, or frozen. I know if I try to "Herk" it out I'm going to destroy it. I just figured I'd get a barbed brass 90 to replace it. anyone else ever face this issue, that brass will unscrew right??
bamaboy is offline
post #2 of 7 (permalink) Old 10-07-2013, 02:50 AM
Ndr
check this thread out. Its been done before with good success.
https://www.vn750.com/forum/showthread.php?t=19832
Ndr is offline
post #3 of 7 (permalink) Old 10-07-2013, 06:47 AM
gibbo's Avatar
I bought a couple of brass fittings as replacements for my broken ones. I had to drill the old ones out, and then pressed in the new ones with some loctite just to make sure. You do have to be careful with the size of the drill and the depth. I went for a 0.001 inch interference fit.
One can never have too many alternative forms of transport.
gibbo is offline
post #4 of 7 (permalink) Old 10-07-2013, 07:00 PM
Seek....and ye shall find..........
http://www.cv-performance.com/cvp-fuel-max-inlet-elbow/
...all Harley custom shops have em for between $12-14/pr....they sell by each though, since Harleys only have one....
post #5 of 7 (permalink) Old 07-29-2014, 09:55 PM
mge_1's Avatar
Send a message via AIM to mge_1 Send a message via Yahoo to mge_1 Send a message via Skype™ to mge_1
Good thread. I found one of the plastic fitting missing (passenger side carb). Is there a quick plastic replacement by any chance?
mge_1 is offline
post #6 of 7 (permalink) Old 07-30-2014, 12:33 AM
Ndr
Not that I've ever found. Though I've never looked that hard for one. Once the plastice piece has cracked off, I do believe that you have to replace the whole inlet as the plastic is molded to the brass. Even if you found an OEM replacement, you still need to pull out the old brass piece and press in the new.
So, might as well get the solid brass piece. With parts and tools in hand, this is quite literally a 5 minute fix if you take your time.
Ndr is offline
post #7 of 7 (permalink) Old 07-30-2014, 08:16 AM
mge_1's Avatar
I was afraid that would be the amswer. Thanks for the input.
I'm looking at the brass fitting now on mine. Can I just put on a 5/16s hose on it with some super glue and clamp it tight? Will that work?
mge_1 is offline
