other tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 09-26-2013, 03:21 PM Thread Starter
vnnikolouzo's Avatar
other tank
does anyone know if EN500 tank ,the one with speedo on top,fit the 750?http://www.ebay.com/itm/KAWASAKI-VUL...-/111171369910
vnnikolouzo is offline
post #2 of 13 (permalink) Old 09-26-2013, 03:55 PM
HardRock's Avatar
The front mounts are different. You might be able to make it work though the tunnel looks about right.
HardRock is offline
post #3 of 13 (permalink) Old 09-26-2013, 07:13 PM
I never heard of an "EN500 Nomad"....the Nomad series was much larger, and were VNs....Im guessing its a VN1500 Nomad tank....and yep....the tunnel is more than fine....like on the Meanie....adding mounting points is easy if you have a welder....
Arizona though Vinny....yer gonna spend $300 on this by time yer done....look for same that needs paint or has dents.....and Im almost SURE its off a VN 1500.....
post #4 of 13 (permalink) Old 09-26-2013, 10:14 PM
Looks like a EN500 tank.
post #5 of 13 (permalink) Old 09-27-2013, 02:23 PM Thread Starter
its a en500 classic i believe and have access to one for about 100 dollars,u think the 1500 would seat better on frame?dont have one around to try it
post #6 of 13 (permalink) Old 09-27-2013, 03:35 PM
The early bubf tank will fit easily with minor adjustment to the front mounts. . Either new spacers need to be made, or something along this lines. Our an adapter plate is needed. I don't remember which.
The en500 would work with about the same amount of work. I have seen both tanks on the 750
post #7 of 13 (permalink) Old 09-27-2013, 09:59 PM
2006 EN 500 Fuel capacity: 15.14 litres (4.00 gallons)
post #8 of 13 (permalink) Old 09-28-2013, 03:09 PM Thread Starter
thanks for imput slim
post #9 of 13 (permalink) Old 09-28-2013, 03:11 PM Thread Starter
thats the tank i'm talking about,its going to look sweet on the 750
post #10 of 13 (permalink) Old 09-28-2013, 03:16 PM
Thinking that rear fender might work too, then the seat.
