smelling gas - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-21-2013, 08:31 AM Thread Starter
smelling gas
ok i'm new to these vulcans i just bought a 1993 vulcan 750 i been having starting issues but most of all in enclosed spaces and even outside theres a strong smell of gas but as far i see theres no leaks no wet spots this can't be normal for this bike someone told me its the vent from the tank but it cant be that strong that it fills my garage and house with the smell of gas?
NKray is offline
post #2 of 6 (permalink) Old 09-21-2013, 09:41 AM
R/R = Relocated Redneck
Jakzen's Avatar
Mine does the same thing, but I don't have any starting issues. The tank vents to atmosphere (directly or indirectly depending on whether or not the emissions parts have been removed). At the same time, if it's getting too much fuel, there could be unburned gas in the exhaust. I would recommend checking the spark plugs. They will tell you a lot about what's going on. There are also a number of threads on here about starting issues. Start with a search in the Vulcan Verses and expand it into a general search.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #3 of 6 (permalink) Old 09-21-2013, 09:47 AM Thread Starter
ok thanks alot for the help i will check that out asap
NKray is offline
post #4 of 6 (permalink) Old 09-21-2013, 10:32 AM
Sometimes the petcock can have a slow leak as the fittings are just pressed in, so one can leak slow enough not to form a puddle.
You can turn the petcock to "off" when parking (lever pulled towards the back of the bike) you just have to remember to turn it back on when you start the bike.
If doing this stops the gas smell you likely do have a petcock leak or a clogged float valve.
post #5 of 6 (permalink) Old 09-21-2013, 11:03 AM
My 01' also tends to have a good bit of gas smell around it but darn if I can find any leaks on it.
Joe in PA is offline
post #6 of 6 (permalink) Old 09-21-2013, 11:16 AM
Smell or strong smell of gas around a parked motorcycle?! Yeah, something wrong with this picture.
Everybody knows how easy it is to check the gas level in the carb bowls. Right? I like to check with the motor running on the center stand also.
edit- if the level is not too high, wad a piece of writing paper and place in the V under the carbs. Leave while parked. Carb and tank vents should not have a gas smell. All tanks and all carbs are vented.
wmsonta is offline
