Number of our carbs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 09-17-2013, 01:19 AM Thread Starter
What is the number associated with our carbs? Cvk34? 36?. Trying to find new rings for em
post #2 of 11 (permalink) Old 09-17-2013, 02:19 AM
cvk34
post #3 of 11 (permalink) Old 09-17-2013, 02:00 PM
SO I can go get two new cvk34 from the KLR 250 and stitch them together and be good?
post #4 of 11 (permalink) Old 09-17-2013, 04:52 PM
...the stitch would be tough, lol....but there are Kawi V Quads that have the same setup....for internals, the CVK34s are same...the externals is what differ...
Honestly, instead of siamesed CVKs, one could run say 2 36mm Mikunis, and would just need to fab a 2 into 1 throttle and choke.....and a mount to keep em from shaking....I still believe its possible to make a single carb manifold for these....my winter project, lol....
post #5 of 11 (permalink) Old 09-17-2013, 07:01 PM
Did you see this build on CC?
Single Carb for the 86 Viargo 1100?
post #6 of 11 (permalink) Old 09-18-2013, 08:43 PM
....sadly, I aint been there in a good month....gonna need to pop in and check out the new stuff.....good, eh ?
post #7 of 11 (permalink) Old 09-18-2013, 08:53 PM
HardRock's Avatar
I single carbed my old Virago with a Mikuni flat slide, made a world of difference instead of those gdmf hitachi carbs that came on the bike.
HardRock is offline
post #8 of 11 (permalink) Old 09-18-2013, 10:01 PM
Really ?....Newrider is workin on a Virago with carb issues.....he could use that info.....(hint)....
post #9 of 11 (permalink) Old 09-19-2013, 03:48 AM
That mod I linked is what I am thinking of trying with the vulcan in a year or so... after I get every thing else sorted out. for right now I just need to stick to my gal of getting it running this winter so I can ride next year.
post #10 of 11 (permalink) Old 09-19-2013, 09:02 PM
I just looked at that mod, and I dont like it....carbs meet too far apart IMO.....ya gotta do a rise and drop, to try to get the carbs closer to the common tube to make it work right....else one cyl will be starving....mebbe can be done in that setup by adding a baffle plate to the closer one to cut down flow.....
I gotta make a drawing as to what Im talkin about.....both carbs should meet the common tube in the same place, or as close as possible....it CAN be done...
Example....if you want the single on the right side, you need to actually make the rear cyl tube go left first, until its closer to the front.....
