Coughing farting & spitting on over run - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-11-2013, 07:58 AM Thread Starter
Question Coughing farting & spitting on over run
Guys and Gals
I know there are numerous threads about popping in the exhaust over run but has anybody got an absoulte cure. My ride has Jardine fish tail exhaust fitted, no centre/muffler/silencer. I have tried the air screw no different. It doesnt back fire as such(loud bang) and all the homeis in gas station hitting the deck, itd pop pop cough cough fart ? !! getting realy annoying.
Michael Strawson is offline
post #2 of 14 (permalink) Old 09-11-2013, 09:24 AM
Coughing farting & spitting.....
Yeah, but what's the bike doing??
What you mean by over run? Did you try marbling/coastering?
With a odd exhaust you might have a jetting issue. The bike should only "pop" when de-accelerating...
post #3 of 14 (permalink) Old 09-11-2013, 09:26 AM
It is either lean or one/both of the cut off valves are stuck.
wmsonta is offline
post #4 of 14 (permalink) Old 09-11-2013, 11:26 AM Thread Starter
At my age theres always the possibility of following through so walk like a penguin.
Its popping on deceleration (Im English !!!!) ive had mixture screws in then out 2 2-1/2 turns, Where are the cut off valves, coasting and marbling I get some very intresting web sights when I google this somebody please explain thanks.
post #5 of 14 (permalink) Old 09-11-2013, 12:14 PM
The coasting enrichers, cutoff valves, are on the sides of the carbs behind the circular plate with two screws. I agree, they are probably not functioning.
Seen at 4:30 in this excellent video by Roach. Don't miss his other videos and part two of this carb rebuild as well.
http://www.youtube.com/watch?v=lPaVmfYhOGg
edit Also, see the enricher starting at #14025 in this diagram:
http://www.bikebandit.com/houseofmot...50021#sch62766
I'm going to disable the coasting enrichers on mine to see if I can get it to pop enough. She popped really nice when I first started riding, then it just cleared up on it's own. (stock pipes) hahaha
post #6 of 14 (permalink) Old 09-11-2013, 01:32 PM
about coastering and marbleing,read the Vulcan verses on this site.also lots more info too.
post #7 of 14 (permalink) Old 09-11-2013, 02:25 PM
Do British/European bikes even have reed valves?
post #8 of 14 (permalink) Old 09-11-2013, 02:59 PM Thread Starter
Reed valves in GB you'd probably blow through it in an orchestra !! If it anything to do with emissions then I doubt Euro spec VN will have them
post #9 of 14 (permalink) Old 09-11-2013, 03:17 PM Thread Starter
Spokster I don't mind the poppin it's the brothers keep hitting the deck they thinks its a drive by yeah we've goten them here!!!
PS deep respect on today of all days to loved ones lost in the twin towers our prayers are with you.
post #10 of 14 (permalink) Old 09-12-2013, 04:58 AM
gibbo's Avatar
My bike was/is an American import, so in the box of bits was all the emissions junk. Michael, is your bike a UK bike or an import? you can tell by the frame number if nothing else. The overrun enrichening device is a small dome screwed one on each side of the carbs, on the left side one of the screws also holds the slow running adjuster. There is a strong spring under the dome so be careful. the rubber diaphragm needs to be intact and there is also a small o-ring to look out for. The diaphragm is attached to a plunger that should slide under vacuum power, this is what sticks, I cleaned mine with some scotchbright. The purpose of all this is to feed a rich mixture on the overrun.
One can never have too many alternative forms of transport.
gibbo is offline
