What do you use when running bike with the tank off? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-27-2013, 08:32 AM Thread Starter
I'm looking for ideas of what other members use as a temporary fuel tank while running the engine with the tank off. I want to inspect my coolant system and check for leaks
1994 VN750
Purchased March 2011 with 14,800 miles
Memphis Shades wind screen, saddle bags
Pulled the exhaust baffles
Relocated the R/R
Manual ACCT's
AGM battery
Iridium plugs
NGK wires
TPE stator
Tuxedo mod
Shindigen MOSFET R/R
7502Yuma is offline
post #2 of 11 (permalink) Old 08-27-2013, 09:37 AM
You can use a lawn mower tank, hang it from the ceiling.
post #3 of 11 (permalink) Old 08-27-2013, 10:09 AM
I'd just put on some longer fuel lines and vacuum line and prop the gas tank up with whatever you got. And yes if you have a ceiling, you can hang it from there. You can bolt it to some wood front and back then build a support to hold it.
post #4 of 11 (permalink) Old 08-27-2013, 10:47 AM
laundry soap bottle set up like an IV drip.....
post #5 of 11 (permalink) Old 08-27-2013, 10:51 AM
Like KM said, or even something stupid like an old hot water bottle... I have a generator that had a plastic tank that split right after I got it, the thing was high dollar and I figured as sorry as it was I wouldn't pay that for it, I removed the outlet from it and installed it in a regular 5 gal. gas can and it is still working after 7-8 yrs. ...
post #6 of 11 (permalink) Old 08-27-2013, 11:09 AM
My neighbor Jack uses a freestanding coatrack with a container hanging (like the IV mentioned, his wife's a nurse)....and he has an inline shutoff valve.
post #7 of 11 (permalink) Old 08-27-2013, 11:56 AM
Just a fair warning. I tried doing this with a funnel and a piece of fuel line. The funnel was dirty, dirt got in my carbs because there is no filter in the tank when you do this. Take caution.
Please learn from my stupid mistakes.
kenny
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
post #8 of 11 (permalink) Old 08-27-2013, 11:59 AM Thread Starter
Thanks for all the great ideas I thought about propping up the tank but I didn't want it to vibrate off. The wheels are turning now!
1994 VN750
Relocated the R/R
Manual ACCT's
AGM battery
Iridium plugs
NGK wires
TPE stator
Tuxedo mod
7502Yuma is offline
post #9 of 11 (permalink) Old 08-30-2013, 02:08 AM
Dr. Vulcanstein
jadabull's Avatar
Like wolfie and kc mentioned. The best way I've used IMO is a fuel bladder.I use a squeeze bottle like you'd use for a bicycle, hang upside down from hanger. I modified the nipple to drip without having to actually squueze the bottle, attached 4' of fuel line with Inline filter.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #10 of 11 (permalink) Old 08-31-2013, 04:49 AM
I use a 1 qt. gear oil bottle with the pointed nozzle cap on it, cut the bottom out of it, drill a hole in the side of it near the top (which used to be the bottom) to hang it by (I usually hang it from the handlebars with a zip tie) remove both fuel lines from the tank, connect them to a T fitting, then connect the spout on the gear oil bottle to the T fitting with a piece of clear plastic hose, and pour some gas into the gear oil bottle. I use this same setup on all my bikes. I put all this stuff in a plastic bag and hang it on a nail in the garage wall to keep it clean until the next time I need it. You can put an inline filter in the clear plastic line if you want.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
