Awfull stutter and not running right - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 37 (permalink) Old 08-02-2013, 03:58 PM Thread Starter
Young Rider
Hi Guys
i just got my cooling problem fixed under guarantee.
drove away bike felt normal.
stopped for gas within a minute of driving away.
filled her up full to neck. Maybe too full?
as i started the bike i drove to the exit of gas station in first gear i fellt her stutter like lack of fuel.
drove away didnt run completely right stopped at a traffic light and a soon as it turned green i pulled the throttle and it died on me.
restarted had to rev it high to keep it not conking out on me.
could this be poogs? even on full tank?
or any other suggestions.
it idles fine until i throttle it.
it only happened after i filled her up though.
juliascox is offline
post #2 of 37 (permalink) Old 08-02-2013, 05:12 PM Thread Starter
Young Rider
nah its on normal not reserve
post #3 of 37 (permalink) Old 08-02-2013, 05:13 PM
Originally Posted by blazblu82 View Post
This might be silly, but check the petcock to see if it was put on reserve or off.
Good thought.....
Doubt it is Poog's.....
post #4 of 37 (permalink) Old 08-02-2013, 05:33 PM Thread Starter
Young Rider
it wasnt on reserve
post #5 of 37 (permalink) Old 08-02-2013, 06:22 PM
If it did this within seconds of closing the gas cap, it is not poog's or a bowl vent problem. If it will always restart immediately, it PROBABLY is not ignition. This trends toward carburetation.
When this happens, can you open the throttle past 25% and have normal acceleration? Always?
wmsonta is offline
post #6 of 37 (permalink) Old 08-02-2013, 07:18 PM Thread Starter
Young Rider
i can but it stutters and then kicks engine also backfires
post #7 of 37 (permalink) Old 08-02-2013, 07:47 PM
Wow, did the shop even take your bike for a test ride before reselling it to you? It sounds like they need to give it some attention..
post #8 of 37 (permalink) Old 08-03-2013, 04:07 AM Thread Starter
Young Rider
as far as i know the dude only let it idle to see when it gets hot that the cooling system worked.
but the weird thing is when i drove away from them i dont think it had this problem.
what they did to the bike was is replace the thermostat because it was faulty which caused my bike to overheat etc.
they also bypassed the fan.
could it be related is the battery to weak could this cause it too?
could it be the spark plugs.
post #9 of 37 (permalink) Old 08-03-2013, 04:30 AM
This highly sounds like so called poog's. Try riding again with the cap open, but closed if you know what I mean. (cap open, but closed, but yet not locked down) If rides fine again then it IS the so called poogs.
Rebel13 is offline
post #10 of 37 (permalink) Old 08-03-2013, 04:46 AM Thread Starter
Young Rider
thanks i will go through the steps later today and let you know progress
