fuel air mix adjustment? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-31-2013, 12:24 PM Thread Starter
oriontheblacksmith's Avatar
hey yall, this might be a silly question but i'm trying to get at my pilot (fuel mixture) screw and theres a plug in the way. how do i get the plug out?
oriontheblacksmith is offline
post #2 of 9 (permalink) Old 07-31-2013, 01:31 PM
I drilled a hole in the center of them with a tiny drill bit in my dremel tool and then carefully pried them out with an ice pick. You can also use a small screw.
Put a stop on the drill so it can only go in 1/8 inch.
post #3 of 9 (permalink) Old 07-31-2013, 07:43 PM Thread Starter
thanks! do i need to put a new plug in after i'm done fiddling with the pilot screw?
post #4 of 9 (permalink) Old 07-31-2013, 08:00 PM
No. They were just put there to keep owners from altering the setting.Once removed there's no point in trying to replace them... Unless you are so paranoid that you think the EPA will raid your house to examine your carbs.....
post #5 of 9 (permalink) Old 07-31-2013, 10:01 PM
Yeah but where are we talkin here? Cali has carb police im pretty sure. Guy i bought mine from was proud it passes north carolina inspection. First thing i did was marble and shave. South carolina is truly the home of the free!
post #6 of 9 (permalink) Old 07-31-2013, 10:21 PM
even in calli, you can knock out the adjusters, because they know carbs come out of tune as the bike ages, and needs to be able to be adjusted to pass smog
post #7 of 9 (permalink) Old 07-31-2013, 11:12 PM
SlowBox's Avatar
All they're concerned with in Texas is the signals. I guess I should count my blessings. I've had a hell of a time trying to get my racecar to pass though. They are catalytic converter and tailpipe nazis.
SlowBox is offline
post #8 of 9 (permalink) Old 08-01-2013, 02:05 AM Thread Starter
word. into the trash they go! i dont think the emmission or inspection laws are that strict in virginia. plus, i work in a shop that does inspections so i'm betting i'll have some wiggle room if i need it
post #9 of 9 (permalink) Old 08-01-2013, 09:15 AM
After I get mine where I want them to stay, I like to put a small amount of silicone at the bottom of the hole. Not real important on vn's. I started doing this on H-D where the screw is vertical and the vibration is pretty severe. Just enough to keep from loosing the screw.
I agree, it means little here. It is a habit.
wmsonta is offline
