Carbs dumping gas! help! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-27-2007, 05:40 PM Thread Starter
engine89's Avatar
Just took the cover off today and fired her up. Ran fine for about 30 seconds then quit. tried to start again ran real rough then gas started dumping out right ear, stalled. heard gurgling sound took out plugs to clean them gas dumped out front cylinder plug hole. plugs on rear also wet. I'm thinking a stuck float is causing gas to fill both carbs thru the tee fitting on the vent line. Took carbs off need some words of wizdom before I take them apart to maybe free a stuck float thanks.
engine89 is offline
post #2 of 10 (permalink) Old 03-27-2007, 06:07 PM
fergy's Avatar
Did you have any seafoam in the gas over the winter? Other?
Now that you've removed the carbs I'd go ahead and clean them as good as possible. I've not been in these carbs so I can't give you advice on looking for the problem. If you hadn't removed them already, I'd be telling ya to add seafoam to the carbs and see if that doesn't free up your stuck float.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 10 (permalink) Old 03-27-2007, 08:15 PM Thread Starter
engine89's Avatar
I used stabil in the gas. If I take the side off to free the float will I have to sync etc. after I,m done or can I just put them back on?
engine89 is offline
post #4 of 10 (permalink) Old 03-27-2007, 09:08 PM
Crobins365's Avatar
If you're pulling the carbs entirely, definitely resync - and I'd suggest not stopping at the float, but cleaning everything as long as you've pulled them off the bike. Make sure all gaskets are good, various vents unplugged, cotter pins there, etc. Anything in there could be the culprint, although a sticky float sounds likely.
But don't worry about the sync job - plenty of folks here who will walk you through it when you get there.
C
Last edited by Crobins365; 03-27-2007 at 09:11 PM. Reason: REalized carbs were already pulled
Crobins365 is offline
post #5 of 10 (permalink) Old 03-27-2007, 10:05 PM Thread Starter
engine89's Avatar
I just checked the tank petcock It dumps gas when turned to on or res does not have pri. This is probably the problem. when I correct this should I monkey with the carbs or just put them back on and hope for the best ? It ran fine last fall.
engine89 is offline
post #6 of 10 (permalink) Old 03-27-2007, 10:14 PM Thread Starter
engine89's Avatar
If the valve is dumping gas shouldn't the float cut it off when the bowls are full?
engine89 is offline
post #7 of 10 (permalink) Old 03-27-2007, 10:33 PM
HAWK
Ccspinner's Avatar
With vacume applied to the valve it will flow free, Yes the floats stop the flow. If the float's stick the fuel will keep flowing.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 10 (permalink) Old 03-28-2007, 08:33 AM
93VN750's Avatar
Depends on the year, some had a "prime" position on the petcock where fuel flowed without vacuum applied.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #9 of 10 (permalink) Old 03-28-2007, 02:50 PM Thread Starter
engine89's Avatar
This bike is a 1990 only has res and on. gas flows out of the tank sitting on the bench with no vac line hooked to it. Is this normal or is the petcock defective. I would prefer not to tear down the carbs if i don't have to.
engine89 is offline
post #10 of 10 (permalink) Old 03-28-2007, 05:43 PM
fergy's Avatar
Is that On/Off/Res? If it has a vacuum port, then it shouldn't be leaking gas with no vacuum applied. That means your petcock needs rebuilding. It's not hard to do at all. I think ronayers.com has the kits. Not sure tho.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
