Performance and Bike Lean - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-22-2013, 05:41 PM Thread Starter
I have been dealing with idle and hot starting issues for a while. I have noticed that my bike idles better sitting vertical than it does on the side stand. Also I have noticed that if I lean the bike to the right the idle picks up for a while and then sometimes bogs down. Sometimes on the side stand the rear cylinder cuts out. Are the idle changes normal or does this point carb issues?
Thanks in advance.
94 with @ 8500mi
AGM Battery
Willie and Max sm. slant bags
Memphis Shield
Splines lubed
trsm4 is offline
post #2 of 5 (permalink) Old 07-22-2013, 05:53 PM
Thanks in advance.
First thought: Check your Float Levels...and wouldn't hurt to Seafoam the fuel system.
Second: Also, Turning of bars RPM changes are sometimes the throttle cables becoming too taunt....re-route/free-up cables if necessary.
Third: Pick-Up Coil Mod is highly recommended to resolve Hot Start issues.
post #3 of 5 (permalink) Old 07-23-2013, 01:18 AM
Ndr
x2
My first thought was the floats in the carb as well as the throttle cables. Stand the bike up and move the handle bars side to side to see if this triggers the change in idle speeds. If so, that might be the worst of it. lube up the throttle cables and see if that solves it. If not, move on to check the float levels.
as for the hot starting, the pickup coil mod is a good idea.
Also, what spark plugs are you running? Iridiums may help with the hot starting as well if you don't already have them.
Ndr is offline
post #4 of 5 (permalink) Old 07-23-2013, 02:46 AM
The sidestand to vertical is fully normal. Its due to the way the CVK carb works...whenever tuning and tweaking, make sure the bike is on the centerstand or vertical....
Also, if your oil level is too high, it can quell the spark on the lower pickup coil....some here refuse to believe it, but its true....I check my oil on the sidestand, and bring it just barely to top...that way when its vertical, should read about 3/4....those marks, H and L....mean "high and low"....theres NO need to ever bring the oil level all the way up to "H".....thats just stupid...some refuse to believe that.....
post #5 of 5 (permalink) Old 07-23-2013, 05:25 PM Thread Starter
I put my bike on the center stand and the oil level was up to the H mark with no air showing. i drained till it should about half. It hard started and then after a while idled just fine. I'm thinking my hot starts were really from side stand starting after filling with gas. Thanks Wolfie, I would never have thought to check the oil level.
94 with @ 8500mi
AGM Battery
Memphis Shield
Splines lubed
trsm4 is offline
