starting prob. grr - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 07-17-2013, 04:16 PM Thread Starter
starting prob. grr
alright i got the vn750 2001 went to start it and turns over smell fuel the backfires. realized choke cable is snapped so i was basically trying to cold start with no choke. anyway this vn has the air box delete so P.O. put air filters directly on carbs. prob didn't re-jet as he was a younger kid.
what jets would be needed. I take plugs out and they are soaked clean them up and yes i have spark but not starting up just backfiring like trying to burn a lot of fuel off the start. also any key ways to start without a choke lol.
Tony G. is offline
post #2 of 14 (permalink) Old 07-17-2013, 04:17 PM Thread Starter
also "muffler" under bike is gone so its just the silencers on the tips.
Tony G. is offline
post #3 of 14 (permalink) Old 07-17-2013, 04:36 PM
How is the battery's charge? Make sure is all charged up or the VN likes to backfire and not start if its low on juice.
I start without choke when it's above 70.
post #4 of 14 (permalink) Old 07-17-2013, 04:42 PM Thread Starter
well i am in fl and its in the 80's i checked the charge and also has a tender/charger hooked to it for good measure.
Tony G. is offline
post #5 of 14 (permalink) Old 07-17-2013, 04:50 PM
sounds more like a float bowl sticking than a lean condition either way the jets recomended for the pod filters are 142 mains and 42 pilots with two shims on the needles
post #6 of 14 (permalink) Old 07-17-2013, 05:00 PM Thread Starter
i'll have to find somewhere local to get the jets and hopefully get this thing going right.
Tony G. is offline
post #7 of 14 (permalink) Old 07-17-2013, 05:15 PM
if you have a cycle gear near by they usually have some in stock and if they dont they can usually get them quick
post #8 of 14 (permalink) Old 07-17-2013, 06:05 PM Thread Starter
all the cycle gears around here when out of business but i'll check with the shop who used to order my parts when i raced.
Tony G. is offline
post #9 of 14 (permalink) Old 07-17-2013, 06:28 PM Thread Starter
I put a trickle charger on her and after sitting she fired right up. Front cyl running smooth as can be. Rear cyl backfiring out of exhaust every 5 seconds then runs smooth. She still isn't warm yet so gonna get her warm ad see what happens
Tony G. is offline
post #10 of 14 (permalink) Old 07-17-2013, 06:38 PM Thread Starter
she got to running temp and smoothed out for the most part. few hiccups which are to be expected. but then shut her off for 2 minutes and when i went to start it up she just turns over. spray a dash of starting fluid and poof. fired up.
confused. when she is cold plugs get soaked and i have to clean them to start her. when she is warm i have to spray start fluid.
Tony G. is offline
