Dumb carb question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-15-2007, 11:58 AM Thread Starter
stan's Avatar
Dumb carb question
I was looking at my carbs and I think I found the lead caps that the fuel/air mixture screws are hidden behind. The question is...how do I remove the lead caps?
oh yeah, the bike is an '04 vn750
VROC #12293
2004 VN750
MSF Ridercoach
new tires (OEM Stones) 6/2008
home made floorboards (knifemakers styling)
stator replaced 6/2008
cobra slashcuts 7/2007
clear alternatives brake & tailight 8/2008
Added Mutazu hard bags 3/2009
added customLED load equalizers for the bags LED lights 3/2009
stan is offline
post #2 of 7 (permalink) Old 03-15-2007, 12:56 PM
Crobins365's Avatar
Not dumb at all. The answer is 'very carefully." I used a tiny drillbit and gently worked my way into the lead - I think the screw is located probably no more than about 5-6mm behind the plug. Since the lead is soft, you can work the drill with very little pressure - I stopped when the bit had clearly bottomed out on the screw.
If you can get the hole started, shouldn't be a problem to then pop out the plug.
C
Crobins365 is offline
post #3 of 7 (permalink) Old 03-16-2007, 11:11 AM
fergy's Avatar
I used a tiny flathead screwdriver and put it just on the edge of the cap and tapped on it til I had the edge of the screwdriver blade poked through then I just pryed the cap off with the screwdriver. Didn't poke it in the middle so I made sure I didn't hit the brass screw.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 7 (permalink) Old 03-16-2007, 09:04 PM
You think you found them, or are quite confident you found them?
Would hate to have ya poke a hole in the wrong thing!
Here's a couple pics Dianna posted of the air mix screw locations, just to be sure........
Right Screw
Left Screw
post #5 of 7 (permalink) Old 03-16-2007, 09:55 PM
Crobins365's Avatar
[QUOTE=hyperbuzzin;27657]You think you found them, or are quite confident you found them?
QUOTE]
Good call, Tim!
C
post #6 of 7 (permalink) Old 03-17-2007, 07:57 AM
Rubline's Avatar
You don't need a drill, you can just use the bit with your fingers.
Rubline is offline
post #7 of 7 (permalink) Old 03-21-2007, 07:55 AM Thread Starter
stan's Avatar
Right Screw
Left Screw
thanks for the pics...now I am sure that I found them......Stan
VROC #12293
2004 VN750
MSF Ridercoach
stan is offline
