Cold Blooded 95 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-14-2007, 04:39 PM Thread Starter
Joem's Avatar
Cold Blooded 95
My 95 is particularly difficult to get started when it is cold, under 50 degrees or so. I sometimes have to hold in the starter button for 30 seconds to a minute before it will keep running. This is with the choke on full. I saw a mention on another thread about starting with the petcock in the PRIME position. Does this work, and do you still keep the choke on?
Joem is offline
post #2 of 8 (permalink) Old 03-14-2007, 04:44 PM
93VN750's Avatar
Unless your carbs are dry for some reason, you should not have to run from the prime position.
30 - 60 seconds is a long time to run the starter. If your engine is cold, use the full choke. Do you give it a little gas while cranking it?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 8 (permalink) Old 03-14-2007, 05:20 PM
fergy's Avatar
You'll overheat your starter motor if you hold it more than 10-15 seconds. It should start in the first second or two unless something's wrong. Obviously that's why you're asking.
If you're getting fuel to the chamber and enough spark, unless you have a compression problem it should fire off. Check your coil voltage at the red wires on each coil and compare that to the voltage of the battery with ignition on but engine not running. If the coil red wire is much lower than battery voltage, you might need to check connections for corosion. If that voltage is good, and you're getting good spark, then you might need to replace your plugs. When I replaced mine with iridiums, my cold starting woes went away. Iridiums have a hotter spark so they fire off on a cold engine better. Plus they can create that spark with less voltage. Anyway, check some things out and let us know.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 8 (permalink) Old 03-14-2007, 09:31 PM
Sky Rider's Avatar
A 95 won't have the Pri(me) position on the petcock. It will have off, on, res.
Do you have a maint free battery? With more cold cranking amps, it will help your hard starting problems as well.
Way too long on the starter. Remember, if it burns out, they're about $400 new. Not cheap. You may be able to find a used on on Ebay or similar but for all you know, it could have been abused as well.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 8 (permalink) Old 03-16-2007, 05:05 PM Thread Starter
Joem's Avatar
I am going to try new plugs. Mine does have a PRI, no OFF. It is really only a problem when it's cold. On warm days it fires right up.
Thanks
Joem is offline
post #6 of 8 (permalink) Old 03-16-2007, 05:09 PM
Uber Member
my vote is either plugs/wires or the battery isnt holding under load. Plugs should prolly be replaced anyway. Check wires for continuity, and battery can be load tested at about any auto parts house
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #7 of 8 (permalink) Old 03-16-2007, 06:10 PM
Batteries certainly can be temperature sensitive. Make sure you got a good charge on it.
Foxhound is offline
post #8 of 8 (permalink) Old 03-17-2007, 02:32 PM
Sky Rider's Avatar
Someone must have switched your petcock as the 90s series bikes had the "newer" petcock without the Pri position.
As long as it functions correctly, it is not an issue though.
I tend to believe you have a battery problem or a dirty connection somewhere.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
