Adjusting Air Mix Screws Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 32 (permalink) Old 07-08-2013, 11:37 AM Thread Starter
Young Rider
hi guys,
ive been reading allot about the air mix screws adjustment.
because i had allot of popping of the exhaust.
so went to check how far the screws were turned by the last owner.
they were pretty far i reckon about 3 1/2 turns OUT.
ive screwed them both out to just over the 2 1/2 mark.
but the bike whenever i opened the throttle it didnt want to rev down so i twisted the idle screw (the black knob) to bring it down to 1100 rpm (IDLE)
but it doesnt seem right after taking it for a 45 min spin.
the bike doesnt rev down fast enough as it normally should.
today even one time at the traffic light it stayed for about 10 seconds just under 3000 rpm.
so what am i doing wrong should i adjust the air mix screws out more or in ?
juliascox is offline
post #2 of 32 (permalink) Old 07-08-2013, 11:56 AM
Okiebezer's Avatar
Soooo... It didn't do this before adjusting the air mix screws?
Sounds to me more like a sticky throttle cable.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #3 of 32 (permalink) Old 07-08-2013, 12:12 PM Thread Starter
Young Rider
im open to anything so how would i deal with a Possible sticky throttle cable?
post #4 of 32 (permalink) Old 07-08-2013, 12:14 PM
It may be a sticky throttle cable, or one of the carbs is loose causing an air leak (and thus a slow-to-idle siatuation).
Well if its a sticky throttle see if cable routing is an issue. If it isn't try lubing the cable. Worst case, replacement if it is damaged.
post #5 of 32 (permalink) Old 07-08-2013, 12:19 PM
Okiebezer's Avatar
Another way to try checking cable is to pay particular attention to the feel of the throttle itself. When you ease off on the twistie, does it return easily by itself or can you make the idle lessen by helping the twistie back to the low throttle position? I noticed this trait after rebuilding my carbs, I had somehow pinched my cables when refastening them to the throttle body. I adjusted the mounting bolts some, but still had a slight delay in the twistie response. I've just dealt with it by the way I twist the twistie.
post #6 of 32 (permalink) Old 07-08-2013, 12:33 PM Thread Starter
Young Rider
but this cant have happened by the idle screw right?
and the air mix screws?
because it doesnt feel like the throttle is sticking at all.
it goes back to start position as it should but the revs go back a few seconds later.
post #7 of 32 (permalink) Old 07-08-2013, 12:35 PM
Nothing to do with the air mixture screws.
My bet is you may have a loose carb/carb boot if your cables are closing properly @ the carb side of things.
post #8 of 32 (permalink) Old 07-08-2013, 01:01 PM
x2 I too experienced slow rev drop back to idle, sometimes as long as 10 + seconds....discovered Air box to carb boots leaking....another symptom I had was 3K rpm difference <> Hot & Cold idle.
Seal your carb boots !
post #9 of 32 (permalink) Old 07-08-2013, 01:47 PM
Julia, if in your shoes, I would verify throttle cable adjustment. When adjusted properly, the return cable has a positive means of closing the throttle. The manuals list the adjustment procedure.
The idle mixture screws are only a backward patch when dealing with deceleration popping. On the VN, the cutoff valves operation should be able to verify by touch. They are both facing out.
Verify proper 'choke' operation visually.
If the cables are adjusted properly, high remaining idle will be caused by air (carb boots, vacuum leak, etc), or excessively lean.
wmsonta is offline
post #10 of 32 (permalink) Old 07-10-2013, 01:50 PM Thread Starter
Young Rider
allright ive done some throttle cable adjustments and now it snaps back.
ive readjusted the airmix screws to 2 1/2.
bike had huge problem starting could this be due to me using the throttle evry time to see if it snapped back?
my exhaust fired loud pop.
but finally started let it run warm and in idle its fine but when i crank the throttle it takes forever to come down.
here is a youtube link.
the video is me trying a hot start en cranking the throttle.
http://youtu.be/q6TvsIDcEV0
by the way found out i have the yuasa yb14l-a2.
could this be a bad battery ?
let me know
