dying carb - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-07-2007, 03:36 PM Thread Starter
"ya can't live forever"
artman's Avatar
dying carb
Riding at 60 mph and above for 5 minutes rear carb cuts out altogether !!
Slow down , pull over and it'll run fine till reaching 60+ and it starts all over again. Help !!
Pugs etc. are fine
artman is offline
post #2 of 9 (permalink) Old 02-07-2007, 03:47 PM
93VN750's Avatar
If you go wide open throttle when that happens, will the rear carb come back?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 9 (permalink) Old 02-07-2007, 03:54 PM Thread Starter
artman's Avatar
yes it does but will only accelerate and not hold at cruising speed
artman is offline
post #4 of 9 (permalink) Old 02-07-2007, 04:07 PM
Uber Member
how many miles you got? how did you make sure its the carb, not something like a spark issue? any changes at all before this happened (filling at a different station, sat for a while ect)?
well help get u back up and running in no time flat
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 9 (permalink) Old 02-07-2007, 04:39 PM
93VN750's Avatar
Sounds like a needle jet problem as this is most of the flow form 1/4 to 3/4 throttle. The fact that you can not cruise but can accerate looks like you have gas flow to the carb, but perhaps are losing the mid range.
Have you ran any seafoam through it recently?
If you have your air box, this is a challenge. If you don't, then just pull your tank and pop open the cover of the rear carb and pull the needle out and see whats up. Check the spring and the diaphragm.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 9 (permalink) Old 02-07-2007, 05:16 PM Thread Starter
artman's Avatar
22,985 m
Hizzo, I didn't say the carb was bad, I just said that it cuts out.
No changes of any kind this situation just popped up.
artman is offline
post #7 of 9 (permalink) Old 02-07-2007, 05:18 PM Thread Starter
artman's Avatar
Yeah I intend to get rid of that air box as soon as my jet kit and filters come in.
artman is offline
post #8 of 9 (permalink) Old 02-07-2007, 05:18 PM
93VN750's Avatar
All the more reason I'd say you've got a clogged passage in that carb.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 9 (permalink) Old 02-08-2007, 04:24 PM
Uber Member
sounds like you are in need of a basic tune up... seafoam (i suggest filling the bowls and let it soak after you run some into the jets too....), plugs, and check on your wires...
let us know if that doesnt resolve it.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
