Premium, Mid grade, or regular? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 02-07-2007, 10:20 AM Thread Starter
I just wanted to know what grade of gas i am to use. I use Premium is this bad for the engine?
LurchChaos is offline
post #2 of 22 (permalink) Old 02-07-2007, 10:25 AM
regular gas is fine for the Vulcan....not sure if premium is bad for the bike but it IS for your wallet
TrashLord is offline
post #3 of 22 (permalink) Old 02-07-2007, 10:27 AM
Search Goddess
Dianna's Avatar
Our bikes are designed, engineered and intended to run on regular gas. Higher octane gasoline does not burn off effectively and can eventually cause buildup. If you have been running premium, start weaning your bike off of it.
Your bike will feel better and your wallet will too.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 22 (permalink) Old 02-07-2007, 10:40 AM
Drive less, ride more...
theauhawk's Avatar
If you want to "pamper" your engine, instead of using premium grade fuel, you'd be much better off instead switching back to (and staying with) regular grade....and using about 4 ounces of "Seafoam" fuel treatment at one fill-up, about once a month.
Also: use Seamfoam--and stay away from "Stabil"....
theauhawk is offline
post #5 of 22 (permalink) Old 02-07-2007, 10:53 AM Thread Starter
Ok,
Now here is the thing. I do notice a diffrence in responce between the premium and the regular will the seafoam compensate? My last bike a VF750 interceptor i ran 108 octane racing fuel in. There was a real diffrece there untill i spun a main bering dooing 135.
post #6 of 22 (permalink) Old 02-07-2007, 11:02 AM
93VN750's Avatar
Originally Posted by LurchChaos View Post
Ok,
Big difference between that v4 honda motor and our v2. Stick to regular unleaded in your Vulcan.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #7 of 22 (permalink) Old 02-07-2007, 11:42 AM
theauhawk's Avatar
Seafoam does a wonderful job of fighting/removing moisture & fuel residue in fuel systems and lines...and keeps carbs/fuel injectors clean. Also lubricates engine's top end. Pour Seafoam in first, then top off your gas tank.
What you'll find is that Seafoam really does it best when it's allowed to sit overnight both in the carbs and the tank for a couple of days.
And, depending on how much build-up you have in your bike, more than one or two treatments of the stuff may be necessary.
Anyway, others here on the forum agree...it's a "tune-up in a can"....
For another perspective on Seafoam, click on the following link:
http://www.webbikeworld.com/sea-foam/
post #8 of 22 (permalink) Old 02-07-2007, 01:40 PM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
I concur with other responses here, use regular, it's what the bikes designed to use, and will cause the least problems with fouling, etc...
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #9 of 22 (permalink) Old 02-07-2007, 05:37 PM
i use mid (89 octane) no fouling problems and seems easier to fire up first thing in the am. i get better gas milage by about 2 or 3 mpg. with its samll tank and limited range that 2 or 3 miles is a livesaver at times.
ride m safe J
free wheel-e is offline
post #10 of 22 (permalink) Old 02-07-2007, 08:09 PM
Cool
I am using 93octane in my bike.I think this subject was brought up before!I use the 93octane for the anti knock qualitys.I hate it when an engine wants to {ping}knock I also put a few drops of acetone in to it helps to atomize the fuel better.No carbon deposits.Better ignition cleaner burn.Thats the ticket..............
Krawdad7 is offline
