Fuel trouble - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-20-2013, 11:28 AM Thread Starter
Lionheart's Avatar
Fuel trouble
Hey guys I'm getting horrible gas mileage and have discovered fuel in the crank case, someone told me sea foam could fix the float problem or else I'm going to take the carb off and clean it, want to try the sea foam first just wondering where and how to use it, a little feed back is greatly appreciated
Lionheart is offline
post #2 of 9 (permalink) Old 06-20-2013, 11:59 AM
Just a regular guy
Chris32250's Avatar
Buy a can at your local auto parts store and pour 2-4 oz in your gas tank... the rude it like you stole it! If its just crud in the tank getting to the carbs this might help burn it out... might wanna try a couple of doses.
Also check the Carb section the is a thread near the top if the first page describing a back blow method...
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #3 of 9 (permalink) Old 06-20-2013, 12:34 PM Thread Starter
Lionheart's Avatar
So spraying it in the gas tank could possibly unstick the float? And if that doesn't work try the blow backing method
post #4 of 9 (permalink) Old 06-20-2013, 03:28 PM Thread Starter
Lionheart's Avatar
Because the main proble are the floats, I've seen videos where they spray it somewhere else so I should put it in the gas tank on an empty tank and fill up correct? And then ride the heck out if it
post #5 of 9 (permalink) Old 06-20-2013, 04:00 PM
Just pour 2-4 oz in a full tank of gas. Ride spiritedly. Repeat.
If it does not work try Wolfie's black-back trick.
post #6 of 9 (permalink) Old 06-20-2013, 04:22 PM Thread Starter
Lionheart's Avatar
Thanks for the info guys ill be sure to get back to you and let you know how it does and if it works
post #7 of 9 (permalink) Old 06-20-2013, 06:15 PM
Deviate's Avatar
And when most of us talk about sea foam, we are talking about the can/bottle that you pour, not the spray version.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #8 of 9 (permalink) Old 06-20-2013, 06:26 PM
Just a regular guy
Chris32250's Avatar
Like Deviate said... its a liquid... just like fuel... the spray would be a cleaner similar to Carb or brake cleaner.
===2001 Vn750====
Ears shaved
Sportster pipes
post #9 of 9 (permalink) Old 06-20-2013, 07:20 PM Thread Starter
Lionheart's Avatar
Wow good thing u told me I would have bought the wrong thing thank you for the helpful advice
