Haul ass, works great. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-20-2007, 10:06 PM Thread Starter
When I just cruise, it seems that my bike is lacking power. When i haul ass, something kicks in, and it runs like a stripped ape. Any suggestions?
ssmendez is offline
post #2 of 6 (permalink) Old 01-20-2007, 10:48 PM
93VN750's Avatar
Can you tell us about the bike? Is it stock? If not, what mods have you done?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 6 (permalink) Old 01-21-2007, 03:45 AM
What do ya mean 'just cruise' mph wise?
If you're cruising at about 50mph in 5th gear, then just twist the throttle hard, and it doesn't seem to have any pick-up to it, downshift before ya twist.
I'm guessing ya don't have the rpm's up enough for the power you may be expecting.
post #4 of 6 (permalink) Old 01-21-2007, 04:00 PM
Uber Member
yeah give us more info.... what rpms the bike sitting at, what mods, when did u last seafoam....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 6 (permalink) Old 01-22-2007, 12:28 AM
Mushu's Avatar
Send a message via MSN to Mushu
One thing to look for, as I found out this weekend, is the right side front cylinder spark plug cable (don't know how old is your bike but mine is about 13 year old) and the rubber boot was cracked and the high voltage was jumping from the spark plug cable to the throttle cable (is surrounded by some wire protection) but only does it a low RPM's. After putting some electrical tape around it (temporary fix) I have more power specially at 2000 RPM's or so. This could be what you are experiencing...
Just my idea...
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #6 of 6 (permalink) Old 01-22-2007, 09:05 PM Thread Starter
My bikes an '86.Idle at about 1100. It seems to me,that the right,front spark plug,is the culprit.I might check the boot.Could just be a bad plug.I'd like to put racing [yellow] wire's on it.I think it would be really sharp looking.
ssmendez is offline
