Bike Runs Terribly After Re-Jetting.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-31-2006, 03:49 PM Thread Starter
93VN750's Avatar
I pulled motor, did stator, shaved the ears, re-jetted (40/140F, 40/142R), put on MAC aftermarket pipes, synch'd the carbs, and it runs terribly.
Does not want to rev up, load or no load. I struggled to get to 65mph, don't think it would have gone much faster if I tried.
Idles better than ever, starts instantly.
I don't know if it's too lean or too rich now, but it's bad. Should I have gone ever bigger on the jets due to shave and pipes?
Any thoughts?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 10 (permalink) Old 12-31-2006, 05:26 PM
Geek
rnewell's Avatar
What do the spark plugs look like ? They are your jetting meter...
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #3 of 10 (permalink) Old 12-31-2006, 05:49 PM
There is also mention of shimming the carb needles in the Verses. Did ya do that too?
Going by what it says in the Verses, you end up needing to shim them nearly 1/4 inch each (2-.126" shims per side).
Pick had mentioned adding 4 shims to each needle, but didn't say what size he used.
post #4 of 10 (permalink) Old 12-31-2006, 06:05 PM
Now what
Ironman's Avatar
What did you do with the vent hose that was behind the right ear?
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #5 of 10 (permalink) Old 12-31-2006, 06:25 PM Thread Starter
93VN750's Avatar
Thanks, forgot, put 2 shims under each needle.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 10 (permalink) Old 12-31-2006, 06:28 PM Thread Starter
93VN750's Avatar
The vent hose is tied to a coolant line out of sight.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 10 (permalink) Old 12-31-2006, 06:30 PM Thread Starter
93VN750's Avatar
From what I have read, this thing screams lean. The 40/140F and 40/142R, + 2 shims is for ear shave alone. I think that adding an aftermarket exhaust (removing the goat belly) requires more when coupled with an ear shave.
The question is how much and where, jets, needle shims, both??
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 10 (permalink) Old 12-31-2006, 11:52 PM
Uber Member
Jon
Hate to say this, but this is some of the fun of carbs. you have to play with them. without an o2 sensor to put in the exhaust to see where your burn lies in, that adds to it. I would start with what was suggested, and go from there.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 10 (permalink) Old 01-01-2007, 02:53 AM
Geek
rnewell's Avatar
Again, watch your spark plugs. They will tell you.
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #10 of 10 (permalink) Old 01-01-2007, 09:59 AM Thread Starter
93VN750's Avatar
I have 8 more shims to play with, I'll order some higher size jets, and begin playing!
Thanks all.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
