No more whistling gas cap....POOG eliminated - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 05-26-2013, 07:32 PM Thread Starter
Like so many here, my ‘06 really suffered with POOG (Phantom Out Of Gas) issues. With each tank of gas, once it was down to 1/4 remaining (approx 90 miles), I would feel the bike bog down as if it was running out of fuel. Like you, I’d pull over, open the gas cap letting some air in the tank and then proceed on my way. At the very least it was a PITA....of course safety was a concern too. Additionally, there are many threads about the gas cap whistling.
If you have ever taken the gas cap apart, you know it’s a complicated bit of engineering.....in addition to the lock, it has screws, springs, gaskets, valves, machined channels....all designed to keep the gas in and let the tank breathe. Problem is, the tank can’t breathe because (IMHO) the damn thing is over engineered.....and the whistling you hear is the tank TRYING to suck air in through the two valves.
I finally eliminated the problem by removing the small valves and gaskets (pictured) and replacing them with a small piece of air filter sponge (the kind of filter used to replace a lawn mower air filter). After several tanks, the gas cap no longer whistles and I have not experienced the dreaded POOG issue.
Note: if you decide to take the gas cap apart, be careful....some of the parts are very small and easily lost. Good luck!!
VoIPDoc is offline
post #2 of 19 (permalink) Old 05-26-2013, 08:56 PM
Awesome, I've been thinking about this issue lately since the temperature is warming here I've noticed it whistling more often, and was thinking there must be some way to help it breathe. Trying this as soon as I get a chance.
Fenris is offline
post #3 of 19 (permalink) Old 05-26-2013, 10:08 PM
OK, now I have been fortunate enough not to experience POOGS, but the other day I was riding to work and was all along on a back road. All of a sudden I heard this loud whistling and thought there was someone with a siren behind me. I didn't post anything because it went away as quick as it came about a mile further down the road. Had me completely baffled and it hasn't happened since. The noise didn't change at all when I pulled in the clutch and let off the gas, stayed the same the whole time, is that what you were dealing with?
post #4 of 19 (permalink) Old 05-26-2013, 10:44 PM
No shark, that is unknown background noise.
Rebel13 is offline
post #5 of 19 (permalink) Old 05-26-2013, 11:43 PM
I usually use Bean-O to stop the whistling gas...
post #6 of 19 (permalink) Old 05-27-2013, 12:11 AM
Chasin' the blacktop
Spencer1's Avatar
I may try the sponge idea myself but I an a little conscerned that the tiny bit of sponge could become plugged with time.
North Georgia
Spencer1 is offline
post #7 of 19 (permalink) Old 05-27-2013, 07:20 AM
JM2001's Avatar
Thanks for the post. Good info.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #8 of 19 (permalink) Old 05-27-2013, 10:49 AM
What is that suppose to mean?
post #9 of 19 (permalink) Old 05-27-2013, 11:20 AM
Did your cooling fan kick on? Some times the fan will make a wierd sound when it comes on.
post #10 of 19 (permalink) Old 05-27-2013, 12:00 PM
I had the unfortunate experience of having POOGS myself. I took apart my gas cap an cleaned it out. I don't recall seeing the pieces you have in the photo so maybe mine was different??? I did remove a rubber piece that was held in by a small rubber nipple in the center of the cap. It was deformed (probably from carb cleaner) and falling apart so I just removed it. It appeared to be a type of flapper valve. I have had no proplems with whistling or POOGS since.
Now you have me thinking....maybe I should take it apart again to see if I need some type of filter piece in there myself. Had no issues yet with dirt or moisture in fuel, but it you made me curious.
Thanks for posting!! I will re-visit the gas cap assembly as soon as time allows.
