type of fuel to use - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 11-26-2006, 02:12 PM Thread Starter
type of fuel to use
I recently purchased a 2001 VN750. Previous owner said he uses 93 octane, is this the proper gas to use, or can one use regular (87 octant)?
Thanks for any reply.
mooneymadness is offline
post #2 of 14 (permalink) Old 11-26-2006, 02:48 PM
Geek
rnewell's Avatar
Regular works just fine.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #3 of 14 (permalink) Old 11-26-2006, 03:17 PM
87 octane is what the manual recommends to use.
post #4 of 14 (permalink) Old 11-26-2006, 03:29 PM
Uber Member
use good old 87, it runs fine... personally i run 89/91 though. i've noticed that i get about 2-3 mpgs extra on freeway, no change in city. with the 93 though u will have to run sea foam more often as it seems to gunk up the carbs.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 14 (permalink) Old 11-26-2006, 06:28 PM
Sky Rider's Avatar
I use 87, no probs.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 14 (permalink) Old 11-26-2006, 06:31 PM
Benjammin'
BSkaggs513's Avatar
Gas....
I was running 93 all the time until I read in here that 87 works just as well. I have been using 87 for several tanks and saw no difference at all, other than the few extra $$ in my wallet. I did, however just run some Seafoam through my bike and did see a difference, so the high octane must have been adding some carbon or gunk to my system. One more reason why these bikes ROCK!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #7 of 14 (permalink) Old 11-27-2006, 11:10 AM Thread Starter
Thanks for all the help. I will put in seafoam and switch to 87 octane.
post #8 of 14 (permalink) Old 11-27-2006, 03:03 PM
Eeeek!?
Doh, I am definitely going to 87 octane. My manual for my '95 says use the high octane!
JohnBoy750 is offline
post #9 of 14 (permalink) Old 11-27-2006, 04:03 PM
fergy's Avatar
I've read where folks here say their manual says 87 and some say it says high octane. Most of us run 87 just fine. Seafoam once a month too!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 14 (permalink) Old 11-27-2006, 06:15 PM
I'm pretty sure the manual does say something about a higher number octane, but that number isn't the one that the gas stations in the USA go by.
They go by the RON(Research Octane Number) + MON(Motor Octane Number) / 2 , or usually shown on the pump as (R+M)/2.
I got this from Wikipedia....
87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-95 (regular) in Europe.
