Runs... but not for long. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-16-2013, 03:12 PM Thread Starter
Have an 85 that is being more testy than my ex.
She starts up fine (well, cold natured but I choke it for a bit and then she's good... Kinda like my ex too. But back to the issue)
Took it out to go get dinner the other night and after about 5 minutes I saw the temp gauge do its normal climb so I turned on the fan (i have it wired to a switch just in case) about 200yds later I stopped at a light and she died.
Pulled over and attempted to restart with no success.
Cranks and cranks but no start.
Opened gas cap, choked, nothing.
Left it there overnight and when I returned in the morning it started right up.
This is meant to be my summer daily.driver and it is boggling my mind.
(sorry if this has been discussed in other posts. I'm on my phone and it's a pain to surf)
Violence never solved anything. Except pacifism.
Me: I prefer to take all my turns on 2 wheels.
Her: Isn't that a little reckless?
Me: Not when that's all you've got
1985 750 Plasti-dipped tins, side covers etc. Mostly blacked out.
djlunatik is offline
post #2 of 6 (permalink) Old 05-16-2013, 03:24 PM
Maybe check the battery voltage, charge voltage, and voltage when the fan is on at idle. Word is, that the ignition starts to fail when voltage drops.
post #3 of 6 (permalink) Old 05-16-2013, 03:32 PM
check the spark and voltage when it does not start, the regulator might be failing when hot and ignition control unit could be doing the same
92 Stealth
89 Trans Am
67 Camaro
91 suburban v2500
yevgenievich is offline
post #4 of 6 (permalink) Old 05-16-2013, 04:51 PM
R/R = Relocated Redneck
Jakzen's Avatar
I'm having the same problem, except that I can usually get her to start if I crank her with WOT. Going to change the plug wires, put in iridium plugs and an AGM battery and see what it does for me. I've read on other posts that this helps.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #5 of 6 (permalink) Old 05-16-2013, 06:55 PM
In many cases with carbs, it can be standard procedure to open the carb on hot starts. Depends on how long it takes to fire up. If you have to hold the throttle open, and it takes a while cranking before it fires, it may be too rich for some reason.
post #6 of 6 (permalink) Old 05-21-2013, 03:10 PM Thread Starter
Trying the r/r first. As well as plugs. Might relocate the r/r too.
