Surge tank removal is cake. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 11-03-2006, 10:20 PM Thread Starter
Yes, it was easy, and no, I didn't pull one engine mount. I had to remove the mount for the electrical connectors behind the front coil, then disconnect everything from the rear harness and pull it through to the top of the frame, then out the side. It's still a tight fit, but I was able to remove it and clean it out without much trouble. I also learned that I'll be needing the R/R. Woohoo.
So, for all the posts I've read stating that the engine must be dropped or pulled, feel free to go back and edit accordingly.
El_Taco is offline
post #2 of 12 (permalink) Old 11-04-2006, 07:50 AM
Geek
rnewell's Avatar
Keep posting what you find. Some of us with new bikes might have to search for this stuff later down the road.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #3 of 12 (permalink) Old 11-04-2006, 11:06 AM
Uber Member
if you are needing a r/r you may wanna check the stator before you get everything reassembled. the failure order most often goes like this. battery>r/r>stator.
just wanted to give you a heads up.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 12 (permalink) Old 11-05-2006, 10:30 AM Thread Starter
No, I believe it's pretty obvious. When I disconnected the unit, one of the terminals decided to stay in the connector.
Also looks as though they tried to remove the stator, but then halfassed bolted it back in. Probably the R/R and nothing else.
Today I build the carbs.
El_Taco is offline
post #5 of 12 (permalink) Old 11-05-2006, 06:23 PM
Once Banned
cegodsey's Avatar
Of course I'm sure you checked the voltage from the stator at different rpms, and checked the resistance relative to ground, right?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 12 (permalink) Old 11-08-2006, 08:57 PM Thread Starter
No, I just sort of bolted it back in. Wasn't too important at the moment. It's running great so far, but I'm going in baby steps. Baby budget, you know? Today's my birthday. I'm 22 years old, and I spent better than half the day working on the bike.
My best gift was the one I gave myself. I heard it run, and it was good.
El_Taco is offline
post #7 of 12 (permalink) Old 11-08-2006, 09:06 PM
HAWK
Ccspinner's Avatar
Glad to here you got it running. Now the fun begins.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 12 (permalink) Old 11-08-2006, 11:16 PM
Once Banned
cegodsey's Avatar
Well, if it's charging the battery I guess your OK. If not, well then you know what's wrong.
The baby budget might be a bigger budget if you got rid of some of those bikes and cars and things. When in doubt, use eBay.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #9 of 12 (permalink) Old 11-09-2006, 05:04 AM
Well Happy B~Day Dave
Glad ya got the bike runnin' !!
post #10 of 12 (permalink) Old 11-09-2006, 04:52 PM
fergy's Avatar
Dave! Happy Birthday!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
