No Start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 10-10-2006, 01:41 PM Thread Starter
"ya can't live forever"
artman's Avatar
No Start
Ok here goes 1998 VN750 21k miles. New stator, new R/R, new wire harness
and new plugs. Carbs removed and cleaned.......Will not start !!! Ran before
stator replacement. Cranks strong w/mf battery. Spark from the plugs is not
fat blue spark one would expect. Prior to all the work being done plugs in the
front cyl. were sooty black and could not keep bike at idle. Gas tank has been
drained and cleaned along with the petcock.
Before I head to the HD dealer ( not really !) I will put the question to you
as to what I should do next....really losing patience TIA
artman is offline
post #2 of 24 (permalink) Old 10-10-2006, 01:57 PM
Sky Rider's Avatar
Sounds like somewhere in the wire harness replacement, something didn't get hooked up correctly or isn't making good contact. Possibly at the IC ignitor module or at the coils. Might be a dirty ground somewhere in the ignition wiring as well. I'd work backwards from the coils and trace it down that way. If it ran before, it has to be something that happened during the electrical equipment replacement. My .02.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 24 (permalink) Old 10-10-2006, 02:05 PM Thread Starter
artman's Avatar
I've been thinking the coils may be the cause. Could have the red and green wires misplaced on them. The manual does not indicate the terminals for red and green.
artman is offline
post #4 of 24 (permalink) Old 10-10-2006, 02:06 PM
Sky Rider's Avatar
Could be. If the spark is weak, that might be a good place to start.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #5 of 24 (permalink) Old 10-10-2006, 02:12 PM Thread Starter
artman's Avatar
Yeah brother it's extremely disappointing to have put this much work into the bike and get these results.
artman is offline
post #6 of 24 (permalink) Old 10-10-2006, 02:23 PM
Sky Rider's Avatar
I had to take mine in to a mech after I rebuilt the engine because it wouldn't start. Turned out that somewhere during the engine reinstall in the frame, the carbs got bumped out of their boots just enough to stop the engine from running. A casual inspection didn't reveal the problem so I had no idea. The mechs fumbled around for about 4 hours before discovering the problem. Fortunatly they only billed me for 2 hours. At $70/hour, it was still expensive. It was a simple problem but it took a fresh set of eyes on it to find. Your possible crossed wires on the coil are probably on the right track.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #7 of 24 (permalink) Old 10-10-2006, 02:44 PM Thread Starter
artman's Avatar
My God those boots are a PITA. After I figure out this problem those ears are
the next project.
artman is offline
post #8 of 24 (permalink) Old 10-10-2006, 04:17 PM
Geek
rnewell's Avatar
Also, is there gas in the carbs ?
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #9 of 24 (permalink) Old 10-10-2006, 04:33 PM Thread Starter
artman's Avatar
Oh yes you can smell it after a few cranks.
artman is offline
post #10 of 24 (permalink) Old 10-10-2006, 06:47 PM
Once Banned
cegodsey's Avatar
Does it backfire? Could be the flywheel thingy with the magnets on it, or the pickup coils are reversed.
Looking at the wiring diagram, one of the coils gets red and green, the other gets black and green. It doesn't matter which terminal on the coil gets red or green, or which terminal gets black or green.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
