Phantom Hose - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-15-2013, 11:26 PM Thread Starter
mnich797's Avatar
Phantom Hose
While doing Coasters I removed 2 large hoses going to each reed valve. I removed and plugged small vacume hose going to right side of carb. Under the seat. I found a brass emissions valve that still has one fairly large hose attached to it. I removed the valve assy but still have a large hose hanging there. I looked in the manual I downloaded found a picture with no description except "US Emissions" Can this hose be removed, plugged or does a breather need to be attached.
1993 VN750
Purchased 12-26-2012
DPR7EIX-9 Iridium Spark Plugs
De-Goated
Rear Turn Signals Relocated
Splines Lubed
Mac 2 into 2 Staggered Exhaust
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #2 of 8 (permalink) Old 04-16-2013, 12:17 AM
Sounds like you're talking about the hose that runs from the valve to the bottom rear of the surge tank (or air box), you can just plug it so no dirt gets pulled into the the intake.
post #3 of 8 (permalink) Old 04-16-2013, 12:29 AM
Okiebezer's Avatar
^x2
I capped the reed valves with 5/8" rubber caps from Ace hardware prior to fabbing some aluminum coasters. The pack came with 4 caps. One for the rear hose, one for each reed valve assembly and one spare. When I finished the earshave, all that came off.
Okiebezer is offline
post #4 of 8 (permalink) Old 04-16-2013, 01:08 PM
I used a round handy box plug and siliconed it in where the hose went into the bottom of the surge tank.
post #5 of 8 (permalink) Old 04-17-2013, 10:39 AM Thread Starter
mnich797's Avatar
Talking
I traced hose and it did go to surge tank which I plugged for now. I plan on ear shave in near future. Thanks to all who replied!
1993 VN750
De-Goated
Splines Lubed
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #6 of 8 (permalink) Old 04-17-2013, 10:58 AM
I connected my two reed valves together with a small piece of radiator hose.
Kenny
Mercury is offline
post #7 of 8 (permalink) Old 04-17-2013, 11:01 AM
Kenny
You can put small caps on them. Caps can be bought at the local parts store.
post #8 of 8 (permalink) Old 04-17-2013, 11:10 AM
That's what I intend to do later since actual blanks can't be had anymore unless you make them yourself.
