Mixture Screw Location - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-12-2013, 11:11 AM Thread Starter
mnich797's Avatar
I have read the Vulcan Verses regarding popping in the exhaust. Are there any photos of the carb assys on the bike which show the location of the mixture screws?
I found the Vulcan Verses to have some great documented information!
1993 VN750
Purchased 12-26-2012
DPR7EIX-9 Iridium Spark Plugs
De-Goated
Rear Turn Signals Relocated
Splines Lubed
Mac 2 into 2 Staggered Exhaust
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #2 of 4 (permalink) Old 04-12-2013, 11:35 AM
Deviate's Avatar
As luck would have it, yes there are pictures. Cindy put up an album with them. Here is the pic for the air mixture screw:
https://www.vn750.com/photopost/showp...to=681&cat=548
BTW, there is a sticky in the section called Carb Parts - Photos and Labels.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 4 (permalink) Old 04-12-2013, 12:32 PM
Ceal's Avatar
Just as a bonus to what Deviate already told you... if no one has messed with those screws, they might be sealed with a cap.
To get at them, most people recommend to CAREFULLY drill the caps to take them off.
I used a screwdriver and a hammer, being careful not to hit them too hard so I didn't break other stuff. Hitting with the hammer and screwdriver also pops them out if you hit at the edge, so it's easy to take them out.
I guess just do the one you're most comfortable with. I'm not good with drills, so I wasn't comfortable using the method that others had suggested.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #4 of 4 (permalink) Old 04-12-2013, 09:43 PM Thread Starter
mnich797's Avatar
Thanks for the help. I was fortunate the caps had been removed!
1993 VN750
De-Goated
Splines Lubed
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
