Pics for the carb sync set-up? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 10-01-2006, 01:00 PM Thread Starter
Crobins365's Avatar
Hey -
The more I read, the less I know...
I went through the Verses this a.m., and Jim has a really nice post there about where the vacuum ports are on each carb, etc. But then we he says, "Get a 1/.4" T link" and starts describing how to hook that up to the petcock, etc., I'm lost. Does anyone have any pics as to how to set this up??
Thanks.
C
Crobins365 is offline
post #2 of 16 (permalink) Old 10-04-2006, 12:29 AM
dta116's Avatar
Cindy, I will be working on it tomarrow, I will see if I can get you some pics....
Dave
dta116 is offline
post #3 of 16 (permalink) Old 10-04-2006, 08:21 AM Thread Starter
Crobins365's Avatar
Thanks. I think I have the idea now (just keep reading - eventually it's gotta sink in), but want to make sure, just in case.
Also - where does one get a 1/4" t-link? I'm assuming that, like the PVC tubing, it needs to have a 1/8" ID? Also, does it have a shut-off valve?
So many questions... at least I got most of the air bubbles out of my homemade manometer last night, so as soon as I figure out the t-link thing, I'm good to go!
C
post #4 of 16 (permalink) Old 10-04-2006, 09:44 AM
TechMech's Avatar
Cindy,
When I did my carb sync, I just applied an external vacuum source to the petcock. Do you have a mityvac vacuum pump? I hooked mine to the petcock vacuum hose I disconnected at the carb, gave the pump a squeeze, and then proceeded with the sync. No "T" connector involved.
TechMech is offline
post #5 of 16 (permalink) Old 10-04-2006, 10:13 AM Thread Starter
Crobins365's Avatar
Originally Posted by TechMech
Cindy,
I'm afraid I don't...is there some other vacuum source in my home-area (like my shop vac; or the windbag who lives across the street) that might serve the same purpose? I guess I'm not sure where else I'd use a vacuum pump, but I may be overlooking something obvious.
Thanks!
C
post #6 of 16 (permalink) Old 10-09-2006, 07:38 PM
Sky Rider's Avatar
Cindy,
Here are a couple of pics that may help explain a bit. I know you have already accomplished your carb sync but it may help in the future and maybe someone else may have questions as well.
Note that with the alternate vacuum source, you won't need a T fitting. If you opt to use the T, it goes between the carb vacuum nipple, the petcock, and the manometer. BTW, the alternate vacuum source does work! I tested it out today and it works just fine. Be sure to push the plunger back in to release the vacuum before disconnecting it though.
Name:	Petcock Explained.JPG
ID:	142   Click image for larger version
Name:	Alt Vacuum.jpg
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #7 of 16 (permalink) Old 10-09-2006, 08:08 PM
Once Banned
cegodsey's Avatar
I don't know if this was intentional, but I nearly busted a rib when I read this. I don't think the married guys got the joke.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #8 of 16 (permalink) Old 10-09-2006, 09:29 PM
that was bad lol............as for a T fitting try walmart in the pet section aquarium supplies
TrashLord is offline
post #9 of 16 (permalink) Old 10-09-2006, 10:41 PM
Once Banned
cegodsey's Avatar
Now that I look at it, there are two, two, two jokes in one! Depends on your sex, or lack thereof.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 16 (permalink) Old 10-10-2006, 09:09 AM Thread Starter
Crobins365's Avatar
I don't get it (so it wasn't intentional)...what'd I say?
Thanks for the pics, too. Very helpful, and the set-up might save me some time next year when I go to do the sync!!
C
