Expensive Carb Parts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-25-2006, 10:29 PM Thread Starter
Sky Rider's Avatar
Ursula started running rough again today on the way to work. Running rich and bogging down when taking off from a dead stop.
I read in the verses that the "coasting enricher gasket" which I interpreted to read as the air cut diaphram as it's in the location described, could develop pin holes. Both front and rear carb air cut diaphrams have the dreaded pin holes so I ordered a pair of them. Boy, are they expensive!!! $36.61 each at Ayers. Car carb parts aren't anywhere near this much, at least in my experience.
Hope this fixes the problem once and for all.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #2 of 10 (permalink) Old 09-25-2006, 11:33 PM
I wish a guy could just throw on a Holley 2-barrel and be done with it, hell for that matter plain old old TBI setup would probably be cheaper.
Woody is offline
post #3 of 10 (permalink) Old 09-26-2006, 12:45 AM
Uber Member
yeah, someone could rig up a TBI or maybe even a direct port for the cost of rebuilding some of these carbs..... all you would need is a machine shop, a computer and some mid line engine knowledge... in 10 years when i am rich (right?) i plan to do cam, direct port injection and tuned header pipes. I wanna see if i can pull 70-80 hp outta this motor. he he. anyone have any ideas how to go to belt?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 10 (permalink) Old 09-26-2006, 06:03 AM
If it's for something that'll bring a smile to your face, it's expensive, no doubt !!
Hope that fix gets your bike running good again Jim !
post #5 of 10 (permalink) Old 09-26-2006, 07:13 AM
Once Banned
cegodsey's Avatar
Don't shoot me if this is stupid, but have you tried silicone?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 10 (permalink) Old 09-26-2006, 12:28 PM
fergy's Avatar
"I read in the verses that the "coasting enricher gasket" which I interpreted to read as the air cut diaphram as it's in the location described, could develop pin holes. Both front and rear carb air cut diaphrams have the dreaded pin holes so I ordered a pair of them."
Not following you on what part this is that you have pinholes in. Can you describe it in more detail? Just want to learn...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 10 (permalink) Old 09-26-2006, 03:41 PM
Check out this part # (43028-1053 DIAPHRAGM,AIR CUT VAL) on the 'Carb Parts' page at Ayers.
(down at the bottom, middle)
post #8 of 10 (permalink) Old 09-26-2006, 03:52 PM
fergy's Avatar
Found it. Thanks! Never been inside our carbs on these bikes yet.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 10 (permalink) Old 10-07-2006, 11:52 PM Thread Starter
Sky Rider's Avatar
Silicone disolves in gasoline so it won't work to heal a rubber diaphram in the carbs.
Just to update, pulled the carbs today as the intermittant stuttering and misfiring continues. Disassembled the floats and both valves appeared clean. Pulled the jets and they too appeared clean. Blew everything out with air just in case. Both front and rear carbs were jetted identically. 38/132. The main diaphrams look good and have no pin holes that I could see. Float tested the floats and found no leaks. Valves look good. There is a shiny area where the valve meets the seat but the valve is all symetrical with no concave wear spot as per the Clymer's.
I did find that the carbs have been disassembled before as there was some damage to the screws that hold the float bowls onto the carbs and the cotter keys that hold the throttle linkages together were non standard. (Wire with a z bend vice a cotter key).
I also discovered that the carb boots were reversed. Front on rear and vice versa. Since I had to pull both off the cylinder and therefore lost my reference boot, it's been a pain trying to get the carbs back on. I finally gave up for the night and will reattempt on Monday since I have it off.
I am also dreading putting the intake ducts back into the surge tank and then back on the carbs. They were a major pain to get out and I figure they will be a pain to get back in.
I really hope this solves the problem. I am also going to check the petcock and see if it is clogged or otherwise fouled with crud. The fuel that drained from the carb was kind of dirty but none of the jets were clogged that I could see. I took some pics for any who might be interested and will attempt to post them once the job is complete.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #10 of 10 (permalink) Old 10-09-2006, 07:31 PM Thread Starter
Sky Rider's Avatar
Final update.
Ursula is back together and running great. I don't know if the carb tear down helped anything or not but the experience was worth it. The intake ducts were indeed a pain but not as hard as I expected. I'm just glad all the gaskets and O rings resealed. I did notice that once I replaced the air cut diaphrams that my decel popping is almost non existant. I readjusted the mixture needles to about 2 turns out on both carbs. If you experience excessing popping, check those air cut diaphrams. Mine were paper thin in some areas and had many pin holes causing the bad decel popping. The nice thing about these is you don't need to pull the carbs to replace them.
The petcock was clean, so who knows?
Name:	In or Out.jpg
ID:	137   Click image for larger version
ID:	138   Click image for larger version
ID:	139   Click image for larger version
ID:	140   Click image for larger version
Name:	Front disassemble.jpg
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
