Backblowing a carb to clean. - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #21 of 49 (permalink) Old 07-19-2013, 12:23 AM Thread Starter
I made a new tool (attachment) for my compressor to do this (@25psi)....will post pics after this weekend....maybe even a video....if I can find my tripod and figure out my new cam...
post #22 of 49 (permalink) Old 08-05-2013, 11:04 PM Thread Starter
haha. funny guy
Dunno who added this junk to my rep...but really....siiiiiigh.....
post #23 of 49 (permalink) Old 10-02-2013, 12:43 PM
Can you do this with the Carb still on the bike?
vinhtvu2 is offline
post #24 of 49 (permalink) Old 10-02-2013, 01:37 PM
HardRock's Avatar
Yes it can be done with the carbs on the bike.
HardRock is offline
post #25 of 49 (permalink) Old 10-02-2013, 07:15 PM Thread Starter
Like Rock said...yes, definitely....thats why this method was conceived....its a "quick fix", often permanent, to a problem common with CVKs....I learned this from guys who run 38 and 40mm CVK Keihins on their Harleys....
You can actually do it while on the road even if needed....a flat screwdriver and a hose is all thats needed....phillips if you still have your stock intake.
post #26 of 49 (permalink) Old 10-03-2013, 03:01 AM
Ndr
Yeah, this saved us a few months ago on a day trip. Was out with a few friends and my brother. He was on my Rebel, his first trip out for more then the commute to work. He ended up dumping the bike in some gravel, and after getting the bike back up, it didn't want to start. After several tries to get the bike started, and with the battery almost dead from cranking, I remember about this trick.
I pulled the vent hoses of the carb, drained the bowl, and attached one of the vent hoses to the bottom of the bowl.
Worked flawlessly. After opening the petcock back up, the bike started right back up.
Ndr is offline
post #27 of 49 (permalink) Old 10-03-2013, 01:21 PM
Big Nick's Avatar
I think a tube on the bowl drain into a glass jar,might also identify any water in the fuel.for which I'm thinking of installing knobs on my needle valves. Spluttering coffing missing nightmare worries, over a little water!
Big Nick is offline
post #28 of 49 (permalink) Old 10-20-2013, 02:18 PM
Ive written the proceedure one too many times in threads, so here it is as a sticky.
I do the same but with carb cleaner. The red tube that comes with it fits perfectly in the bowl drain for backflushing.
RobertGary1 is offline
post #29 of 49 (permalink) Old 10-20-2013, 04:02 PM Thread Starter
Sure....that'll work too....same principle....I just dont like overusing carb cleaners, including SeaFoam, as they will eventually break down any rubber or neoprene parts....the key is that youre removing dirt/particles in the same direction they entered...
post #30 of 49 (permalink) Old 05-05-2014, 03:02 PM
Thank you so much for this post. Fixed my sticky float problem without pulling the carbs. Now I'm going to dose it with Seafoam(good stuff used it for years) for a few tanks and hopefully not have to mess with it again.
Havok750 is offline
