Vacuum Issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 33 (permalink) Old 09-16-2006, 06:56 PM Thread Starter
dta116's Avatar
Vacuum Issues
Hello again, you may remember me with the fuel problem....
https://www.vn750.com/forum/showthread.php?t=2325
To continue the quest for a better performing bike, I need to know what others have experienced with their vacuum guage.
Mine will wildly swing at idle but will smooth out as throttle is increased.
I syncronized the carbs today and they will sync at 4000 rpm but at idle the rear cylinder has a lot higher vacuum than the front.
I am using Marty's yard stick manometer
http://www.powerchutes.com/manometer.asp
any sugestions? I know from a vacuum check on my car, that the needle should be steady at idle, otherwise you have a vacuum leak or the carbs are too rich or too lean. Which is it for these bikes? Do I need to enrichen the jets? (Oh yeah, I forgot to tell you I only have one vacuum line from the front carb, all the others are gone, and I replaced that hose so probably not a leak.....will the idle adjust effect the sync?
The bike seems to run ..OK, not super, but ok. Maybe I am too pickey and expect this 2 cylinder to run like my '71 honda 750 4cyl.
Thanks for any assistance you can provide.
I will be ear shaving in the very near future and need access to a set of jets and shims, I have tried the links in the verses, but none acctually tell me which jets and shimms are for the VN750.....
Thanks again.
dta116 is offline
post #2 of 33 (permalink) Old 09-17-2006, 11:56 AM Thread Starter
dta116's Avatar
I guess everyone elses' vacuum is fine....
dta116 is offline
post #3 of 33 (permalink) Old 09-17-2006, 01:14 PM
HAWK
Ccspinner's Avatar
I have never checked mine so i cant help
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 33 (permalink) Old 09-17-2006, 01:22 PM
Ditto
post #5 of 33 (permalink) Old 09-17-2006, 10:08 PM Thread Starter
dta116's Avatar
Maybe I will have to repost during the week....
Thanks
dta116 is offline
post #6 of 33 (permalink) Old 09-17-2006, 10:22 PM
Once Banned
cegodsey's Avatar
Me either. Although some people say that the vaccum between my ears is good. I don't know how they know my bike has ears...
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #7 of 33 (permalink) Old 09-18-2006, 11:12 AM
When the bike is at idle "I think 1100 RPM" you will need to restrict the tube to get a steady reading. Most carb sync. tools come with little wire restricters. If yours doesn't you will need to find a way to pinch off the tube a bit. Sometimes a small pair of loccking pliers or small c-clamps. Hope this helps!
tinocker is offline
post #8 of 33 (permalink) Old 09-18-2006, 10:14 PM Thread Starter
dta116's Avatar
tinocker, can you please explain in as much detail as you can, I cannot find any info on this. I can see restriction, but I cannot see how it will help with on side having more vacuum than the other at idle....There needs to be some way to adjust each side????
Thanks.
dta116 is offline
post #9 of 33 (permalink) Old 09-30-2006, 08:31 PM
Crobins365's Avatar
I'm having the same rpm swing at idle - dta116, did you ever find a solution to your problem with the same?
Thanks.
C
Crobins365 is offline
post #10 of 33 (permalink) Old 10-01-2006, 04:08 AM
If you need to set the carbs so one matches (or is in-sync with) the other, I don't see why you'd need to be able to adjust both.
Just adjust the one 'til it is the same (or very nearly the same) as the other.
Or am I missing something else here?
All I could find on a search were instrucions which say "Adjust the dampening valve to reduce the studder of the needle, or mercury"
There were no pictures to go along with it.
