To drain or not to drain, that is... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 01-23-2013, 05:15 PM Thread Starter
The newly purchased Vulcan is going to sit for 2mos. A lifelong friend is an actual motorcycle mechanic. He says I should drain the carbs.
The bike sat for 3+ mos before I bought it. I recently rode it for 7 mi, it ran fine. I own 6 or 8 vehicles, all but my GN are carburetor. I only start/drive them a couple times a year. Since 1988. No real problems.
I keep seafoam and xylene around all the time.
Opinions?
wmsonta is offline
post #2 of 14 (permalink) Old 01-23-2013, 05:22 PM
Drain and backblow.
post #3 of 14 (permalink) Old 01-23-2013, 05:31 PM
Crap, I WAS in 5th gear.
Stabil fuel treatment would be ok for a month or two IF your fuel system is COMPLETELY[/B] sealed from the atmosphere (incluing the float bowl and tank cap vents.) The 10% ethanol that they put in gas now absorbs moisture and gums up. Sure, usually you can get away with several months, but a carb cleaning is not pleasant on our little V-twin.
Kelly2001 is offline
post #4 of 14 (permalink) Old 01-23-2013, 05:43 PM Thread Starter
Well that is 3. Thanks to all that replied. I will drain them.
wmsonta is offline
post #5 of 14 (permalink) Old 01-23-2013, 05:52 PM
Just put the drained gas in your cage. You still need to seal up the fuel tank- don't want it to rust!
post #6 of 14 (permalink) Old 01-23-2013, 06:24 PM Thread Starter
They are drained. Not much in them. Makes me wonder about the float level. I don't know how much longer I will have internet. Supposed to go of the 26th.
Once again, thanks wolfie and kelly.
wmsonta is offline
post #7 of 14 (permalink) Old 01-23-2013, 06:59 PM
If you are still online,you still need to fill the tank and add stabil or seafoam or both,will keep your fuel up to snuff for a couple of months and retard tank corrosion /rust.Fluctuations in temperature will cause a lot of condensation in an empty metal tank.
post #8 of 14 (permalink) Old 01-23-2013, 07:14 PM
romeobravo172
romeobravo172's Avatar
^^^What Denny said, fill it up to max and sit it out. If you feel the need in a couple months, drain it out put in the cage and fill it back up with fresh again. In my opinion, less condensate, rust ect.
romeobravo172 is offline
post #9 of 14 (permalink) Old 01-23-2013, 07:24 PM Thread Starter
Thanks fella's. Tank shows about half full of what has to be old gas. I will try to get a jug of gas and top it off. See if I can make a bigger mess.
On the internet, just don;t know how well ATT has their act together. Where i'm going the internet is government controlled pretty much I understand.
wmsonta is offline
post #10 of 14 (permalink) Old 01-23-2013, 08:19 PM
True about the condensation...but if empty, and the cap is left open, there can be no condensation. Think about a condenser on a still...gotta be almost airtight to work....An empty tank, left ventillated will just dry out. I did it on mine before fixing the holes in it.
