TW200 petcock success - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 74 (permalink) Old 12-23-2012, 06:07 PM Thread Starter
It had been a while since I've visited these pages but I have some useful information that needs to be spread. I have spent the $30 on the Yahama TW200 petcock in an effort to remove the vacuum operated one stock to our bikes. Many people said it wouldn't flow enough for our carbs and I am here to say otherwise. I have done the standard ear shave and re-jetting procedure detailed many times over on this forum, therefore running more fuel. My TW200 petcock works perfectly. I have run for many miles at 90mph+ to ensure my setup works sufficiently. For skeptical people looking for solid proof, simply compare the in-tank portion of the petcocks, they are identical, and therefore have identical flow capabilities.
I highly reccomend this conversion to those experiencing problems with their stock vacuum diaphragm operated petcocks, it costs the same as the rebuild kit and results in less moving parts.
Ticked is offline
post #2 of 74 (permalink) Old 12-23-2012, 09:43 PM
Welcome to the forum.
Thanks, I have a slight issue with my petcock, I will further check out your suggestion.
Thanks again... and Merry Christmas !
WilliamTech
post #3 of 74 (permalink) Old 12-23-2012, 10:34 PM
Old guy
Had a problem with my fuel valve leaking, converted it to strarght manual. No more vacuum line or diaphragm. Just like the old bikes I had, when you turn the engine off you turn the fuel valve to off.
sprint56 is offline
post #4 of 74 (permalink) Old 12-24-2012, 12:02 AM
Some details would be nice (mebbe a pic)....and Im assuming 3 position...off/on/res.....does it bolt right up ?.....
Its really kind of an ambiguous post without the extras....
post #5 of 74 (permalink) Old 12-24-2012, 05:14 AM
wrench
Yamamoto's Avatar
Thx, i will look into this when i get to the fuel tank.
Did you simply block the vacuum line from the carb ?
Yamamoto is offline
post #6 of 74 (permalink) Old 12-24-2012, 07:50 AM
yes, @ the carb.
post #7 of 74 (permalink) Old 12-25-2012, 05:54 PM Thread Starter
It does bolt right up and it just requires, as already mentioned, vacuum lines to be capped/plugged. You'll need a T. My apologies for the lack of pictures and ambiguity that causes , but I really don't think pictures are necessary...it's a petcock replacement.
Ticked is offline
post #8 of 74 (permalink) Old 12-25-2012, 10:40 PM
The description you just provided is fine...thanks...
I just dont understand how it could get the same flow....same size outlet as one side of the stock...I guess this is just an emergency swap for stock VNs....if that...not much of a filter either...
post #9 of 74 (permalink) Old 12-25-2012, 11:05 PM Thread Starter
Yea, the filter portion is pretty cheap, there're probably comparable to the stock ones though. My tank has recently been recoated so I'm not too worried.
I was initially concerned with the flow rate when I received the TW200 petcock, I stared at it for a while before I figured it out.
The most restrictive portion of both the stock and my replacement is the in-tank portion of the petcock. Same size, same flow capabilities. The stock one just has a built in T under the tank. All you have to do is add your own T, I used a 5 dollar cheapie from Autozone. The change to the system after complete installation of (TW200)petcock and T is; the selector(on-off-res) now closes off the line prior to the T. The stock selector was integrated into the T.
dirtydi3sel likes this.
Ticked is offline
post #10 of 74 (permalink) Old 12-25-2012, 11:54 PM
See, many of us have changed over from the crappy plastic Kawi carb inlets to larger ID brass Hi-Flos....I guess with the stock Kawi inlets the Yammer piece would be ok, but beyond that, I just feel it'd be too restrictive....I could be wrong though, as Im willing to bet that a vac actuator can restrict as well if it operates improperly....
Is there enough meat on the Yammy outlet to bore it out some ?....that could work then....
And just so's ya know...I aint tryin to bash yer post...I welcome any mods/innovations...I was just wary of the performance....
