KN filters and jets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-03-2012, 02:41 PM Thread Starter
KN filters and jets
With the consistancy of the KN filter verses the old foam filters. Do I need to make any adjustments on the carbs or rejet them?
Blessings!
Richard
mrseedsower is offline
post #2 of 10 (permalink) Old 12-03-2012, 03:09 PM
Yup, if you're stepping into K&N filters, you'll need to rejet.
There's lots of posts as to which jets to use but if you check out Voip Doc's link in my
Signature, the jets there would be a good place to start.
Of course you should check how it runs after the change, watch your plugs &
Note any lulls in performance. This can tell you if your running, rich, lean or if your good & just need to tweak the midrange by adding shims to your needle.
post #3 of 10 (permalink) Old 12-03-2012, 03:11 PM
Okiebezer's Avatar
Depends
Depends on if you did an ear shave. If using the K&M replacements that fit the standard air box, then most would say no need to rejet. But you may have to adjust the mixture screws.
** I would acquiesce to Kanuck's experience over mine. He has been around a bit longer. I have the K&N replacements for standard box and bike has ran fine for several months. Course, may have run better had I followed his lead. :}
Okiebezer is offline
post #4 of 10 (permalink) Old 12-03-2012, 03:13 PM
JM2001's Avatar
Blessings!
Richard
You should NOT have to rejet. You might have to back out your air/fuel mixture screw 1/2 to 1 turn out if the bike is running too lean.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 10 (permalink) Old 12-03-2012, 03:45 PM
+1
You only need to rejet if you are installing the K+N "pod" type filters that clamp directly to the carb mouths....(or any other pod filter instead of the stock set up)
post #6 of 10 (permalink) Old 12-03-2012, 03:58 PM
been running my k&n stock style replacements for the better part of a year carbs are at three turns out with factory jets no issues yet
post #7 of 10 (permalink) Old 12-03-2012, 05:24 PM Thread Starter
yea, I didn't think about that. I am wanting to replace the ear filters with k&n filters.
Like these
http://detailsreview.com/cheap-kn-ka...cement-filter/
Blessings!
Richard
post #8 of 10 (permalink) Old 12-03-2012, 05:52 PM
if you go with ebay use this guy (autocom_performance) his price is for a set of filters not just one this is who i got mine from and he ships fast $55.97 with free shipping
k&n part number is KA-7586
post #9 of 10 (permalink) Old 12-04-2012, 12:00 AM
Depends on what you read as to whats suggested. I've read posts in the past that state even if you change to k&n in the ears you'll probably have to rejet.
That's why I mentioned checking your plugs & such after the change. See how its running.
You may not have to rejet. But I don't suggest changing to the K&N filters & not checking the results to ensure your not running to rich or too lean.
Perhaps I wasn't clear enough in my first post. Sorry about that.
post #10 of 10 (permalink) Old 12-04-2012, 12:19 AM
no you were clear this is good info
