Carb question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 11-04-2012, 09:32 AM Thread Starter
Waitin2Ride
Mercilessgod's Avatar
Question Carb question
After reading thru the verses on pote4ntial causes of loss of power, I started checking everything, elect connections, ground wire, vent hoses, etc. After the gas tank came off, I was looking around for the one vent line that people say to 45 so it doesn't bottom out and i came across this t-connector in between my carbs that looks like it should have a hose on it, but I'm not sure what it is or where it should go and would it cause an acceleration issue....any thoughts?
Now where did this piece come from???
Mercilessgod is offline
post #2 of 7 (permalink) Old 11-04-2012, 10:11 AM
That T is the one that should have the vent hose on it that goes into the right ear.
post #3 of 7 (permalink) Old 11-04-2012, 10:35 AM Thread Starter
Waitin2Ride
That's what I thought. I took the right ear off but I didn't see a hole for it to go into... is that vacuum line needed, or can i just plug it?
post #4 of 7 (permalink) Old 11-04-2012, 10:50 AM
its not a vacuum line, its a breather line... yes you need it. there isn't a hole per say in the right ear for a hose, but more of a formed tube with a slit in it.
post #5 of 7 (permalink) Old 11-04-2012, 10:58 AM Thread Starter
Waitin2Ride
ok, final question. would adding the tube be recommended or just leave it like it is?
post #6 of 7 (permalink) Old 11-04-2012, 11:04 AM
add the tube... even when we remove he ears, we still run the tube.. just relocated to the bottom of the fuel tank or into the frame... any where out of the wind
post #7 of 7 (permalink) Old 11-04-2012, 11:08 AM Thread Starter
Waitin2Ride
ok, thanks
