Idle is screwey, RPMs high, bike dies... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 10-25-2012, 04:36 PM Thread Starter
Tech/Musician/Friendly
AudibleCreations's Avatar
hello folks,
I've recently had issues with my bike running at high RPMs while Idle-ling. I will adjust the idle before cruising after the bike has warmed up and I'll ride for a mile, stop at a stop sign, and my idle is at 3000 rpms. I'll adjust the ilder back to normal and cruise some more and the rpms at dead stop change. I've had an issue when Im coming to a stop sometimes my idle drops below 1000 and the bike shuts off. At that point I can not restart the bike without squeezing on and off of the vacuum tube from my fuel tap and pressing the start switch.
Can anyone point me in the right direction?
More INFO: 2000 vn750 22,000 miles... I converted my ACCT's to MCCT's the other day and Im sure they are not too loose or too tight. Carbs were rebuilt a couple months ago but the tank was pretty rusty, cleaned that the best I could and I use SeaFoam occasionally.
AudibleCreations is offline
post #2 of 14 (permalink) Old 10-25-2012, 05:03 PM
Just a regular guy
Chris32250's Avatar
I have that problem occasionally when I have rim Seafoam in more than a few tanks.. usually just running a little helps. To me it sounds like some rust from the tank could be in the carbs or petcock. I would check the petcock first...
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #3 of 14 (permalink) Old 10-25-2012, 05:29 PM
idle screwy
try spraying carb cleaner on carb boots, if revs up air leak mine did that and thats how i found it. just a thought
vulcan9896 is offline
post #4 of 14 (permalink) Old 10-25-2012, 05:36 PM
Also, check the enricher linkage for binding, and lube the idle adjust cable too.
post #5 of 14 (permalink) Old 10-25-2012, 06:22 PM Thread Starter
Thanks guys! I'll start with your suggestions and post an update in a day or two.
post #6 of 14 (permalink) Old 10-26-2012, 05:14 PM
Gemguy's Avatar
I had the same issue. when my bike warmed up the idle was erratic and high. It turned out to be the boots that the carbs mount on are made of rubber and they warp. Once that happens air gets in directly to the cylinders bypassing the carb and causing high idle. I think you can check that with smoke from a cigarette or cigar when the bike is idling see if the smoke gets sucked in between the boot and the cylinder.
~VROC~ # 389
Gemguy is offline
post #7 of 14 (permalink) Old 10-26-2012, 07:29 PM
Yes, you can....you'll see the smoke plume being sucked in....good advice Gemguy !
post #8 of 14 (permalink) Old 03-09-2013, 11:51 AM Thread Starter
Wolfie, Im not sure what the enricher linkage is. I tried to find that term in the manual but to no avail. Im competent a quick description is all I need bud!
post #9 of 14 (permalink) Old 03-09-2013, 05:24 PM
JM2001's Avatar
It's what most people consider the choke. Starting at the " choke lever " below the left mirror, trace the cable back to the carbs. You will see a rail with plungers moving up or down.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #10 of 14 (permalink) Old 03-09-2013, 10:13 PM
Thanks JM...was busy shovelling all day, lol....
