Spark plugs too clean, running lean? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-22-2012, 05:40 PM Thread Starter
As the title states. Spark plugs are really, really clean and I'm pretty sure the bike must be running on the lean side. 2 shims, 140/40 jets, K&N filters, 2.5 turns out. Should I remove a shim and see what happens, or try 3 turns out?
vulcanpower is offline
post #2 of 6 (permalink) Old 10-22-2012, 07:49 PM
A pic of the plug would be nice...are they the color of coffee with cream ?...if so, thats perfect. You can try backing out 1/4 turn at a time and test. But w/o seeing the plugs, hard to say.
post #3 of 6 (permalink) Old 10-22-2012, 10:00 PM
Let's Ride!!
DaveT319's Avatar
How many miles should you go between adjusting and checking?
DaveT319 is offline
post #4 of 6 (permalink) Old 10-23-2012, 09:08 AM
Crap, I WAS in 5th gear.
Shims or washers under the needle seat make it slightly richer, not leaner, at cruise with constant throttle.
Kelly2001 is offline
post #5 of 6 (permalink) Old 10-23-2012, 01:02 PM
JM2001's Avatar
A lean mixture is more air related ( too much air ) than fuel related. Check your air intakes, for a leak at the headers, and air filters. After market exhausts could cause this also.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 6 (permalink) Old 10-23-2012, 07:21 PM
20 miles under hard accels should show it (differences).
