Fuel problem, or Electrical? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 08-30-2006, 11:05 PM Thread Starter
dta116's Avatar
My new (Old) bike is experiencing a misfire problem.
1996 with only 2400 miles.
At first it stalled on the way home, after a couple of days of running fine, waited 10 mins and it restarted.
I added Berryman's Chemtool to the tank and ran it the next day.
I then filled up with gas and it begain missing on the front cylinder. Both plugs were wet. I then changed the plugs to no avail. It appeared the front cylinder wa now flooding. I took the plugs out, (they all were firing) and left it for 10 mins, then cranked it over to see a lot of fuel expelled from the front plug holes.
I then decided to clean the carbs, (stuck float ya know!). No more flooding but still missing from the front. the backpressure on the right (front) exhaust is not as strong as the left. Still all plugs are firing when tested against the frame, although not a massive blue flame as in my car, but all four plugs apear to fire approximatly the same strength.
Did resistance check on the coils, OK.
This thing is driving me crazy.... A little help Please.
Oh, yea.... I changed out the gas.
Thanks ahead of time guys for the assistance.
Forgot to say New M/F Battery (Yuasa: YTX14AHL-BS)
09/16/06 Update - I am listing all things done to the bike since this problem started......
... Rinsed out tank with gas.
... Dissasembled and cleaned Petcock and filters.
... Changed oil and filter
... Drain and refil Radiator w/ Dexcool (no water) (I know what they say....)
... Drain and refil rear gearbox
... Relube final drive w/ Honda moly (has been done before, hoorah!)
... Check compression, (Front 160, Rear 155)
... Check vacuum (wildly swings at idle, then smothes out with throttle)
... Sync carbs (synced at 4000, way off at idle)
... Installed Capacitors on regulator wiring
... Wired coils direct to batt. (thru relay)
... Added voltmeter (led) thru relay
... New Plugs (Iridium), Wires and Caps (NGK)
... Just for the record, I think I found the problem, I took the carbs off for the FOURTH time, and found both floats the be stuck closed. This apparently happened when I shot a ton of Gummout in reverse thru the drain hole. At first only the front cylinder was effected, and the more I shot it up, the worse it got. Now remember I have cleaned the carbs TWICE before and once was a soak in carb dunk, so what ever is in the fuel (or was) or whatever is in the Gummout, is not meant for these carbs.
I will copy this fix to the reply, hopefully with all in one post, the answers will be easier to find.
Anyway...the bike is up and running again....
I will start another post about the vacuum problems I am having in another forum
dta116 is offline
post #2 of 21 (permalink) Old 08-31-2006, 04:54 AM
Once Banned
cegodsey's Avatar
I looked up Chemtool, and it is not SeaFoam-like. Other than it is a cleaner. Get some Seafoam, and run 3 oz of that through a tank o' gas instead of chemtool. You might want to get some cheap clear fuel filters to run inline with the carbs for a little while. If the bike only had 2000 miles on it (per previous thread), then it suredly has rust in the tank, or some other such gunk.
It might also be beneficial to you to try Fergy's coil mod. That would give you better spark. http://pages.tstar.net/~fergy/writeu...relay_mod.html
You did change the oil, right? Liquid gas in the cylinder will filter past the rings into the crankcase, and dilute your oil.
Seafoam:
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 21 (permalink) Old 08-31-2006, 06:17 PM Thread Starter
dta116's Avatar
I am sure you are correct, but having used Berryman's for many, many,many years, and trust it's ability to clean fuel systems, I opted to err on the side of caution as I know what it can do and I am not yet familiar with the results of Seafoam so that is my reasoning.
Yes I did change the oil and the gas.
Of course I cannot run a tank of Seafoam if I cannot get the bike to run right.
I appreciate the response as I need all the help I can get.
dta116 is offline
post #4 of 21 (permalink) Old 08-31-2006, 06:30 PM
tankist's Avatar
Send a message via Skype™ to tankist
i'm might not be the best MC tech around here, but it sounds still like carb related to me.
if there is alot of rust in the tank like cegodsey mentioned, your clean carbs will get clogged up again pretty soon.
http://agrasyuk.googlepages.com/home
Anton Grasyuk
Wheeling, IL
tankist is offline
post #5 of 21 (permalink) Old 08-31-2006, 07:00 PM
Once Banned
cegodsey's Avatar
If you do a search on Seafoam in this forum, I think you'll understand how we feel about it. It's primarily 3 ingredients - pale oil, isopropyl, and naptha. At least those are all the ingredients required to be listed on the MSDS. To us, it's magic. I haven't used it in my bike yet, but I have used it in my Honda mower, and I must admit, it's majick!
If I were you, I'd do a compression test on that front cylinder, just in case. Check the igniter (CDI, ingition module) resistance per the manual. You also might try switching the coils. It could also be related to the coil pickups behind the left engine cover.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 21 (permalink) Old 09-01-2006, 01:22 AM Thread Starter
dta116's Avatar
cegodsey - I thought about swaping the coils, but it makes no sense that all plugs are firing about the same intensity.
I will use the Seafoam the first chance I get to ride the bike I just bought and have no miles on......
dta116 is offline
post #7 of 21 (permalink) Old 09-01-2006, 08:15 PM
Uber Member
sounds like a clogged jet it just dripping gas into the intake maybe. I am still learning carbs, but i know what you are describing is very similar to a clogged injector. try nursing it off of some sea foam gas mix. if that doesnt work, sounds like you may have a carb pull on your hands.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #8 of 21 (permalink) Old 09-08-2006, 07:32 PM
SEAFOAM is all you will need... it is the best...
750 FREAK is offline
post #9 of 21 (permalink) Old 09-10-2006, 01:06 AM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Seafoam is a miracle drug, Lena loves it. Put it in my Subaru's oil to see
if it would stop my noisy sticky valves... and it helped quite a bit and
the valve sounds are getting quieter every time I start it up.
Good deal on it here at an ACE Hardware store ... 4.99 for the round can on the right that
CEgosey posted a pic of.
norsseman is offline
post #10 of 21 (permalink) Old 09-11-2006, 08:52 PM Thread Starter
dta116's Avatar
Well, another weekend shot to hell! I rebuilt the carbs and did a hundred other mods while it was down waiting for a lost o-ring........
Cranked her back up sunday, sounded like crap....waited a while and tried again and it sounded better, waited some more and it sounded about right so I adjusted the idle screws, throtle linkage, and Idle then rode about 10 miles. It ran like it is supposed to, (maybe better) so I decided to take it to work this morning.
Well, about 5 miles down the loop doing 60, it starts missing, so I make it to work.
After work I take the city streets back home without problems, but as soon as I get back on the loop to get my exit, It starts cutting out again at around 60mph. I get home and pull the tank and petcock to look-see and everything is crystal clean. what in the world could this gremlin be?
It sounds like a fuel filter but we don't have one (just the tank filter), but I blew that out and checked it thoroughly. It only seems to happen at 60 or better.
I cannot tell if one cylinder or the other is missing.
Anybody interested in a VN750?
dta116 is offline
