Starting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-20-2012, 08:46 AM Thread Starter
Starting issues
My bike is a 93 with 21,000 miles on it and lately it is developing a weird starting issue. If the bike is cold, as in sat for 24 hours I put the choke on and it starts right up with no issues. If say I ride it for 10 minutes and then get back on it 4 hours later, it is basically cold so I turn the choke on but then it acts like its flooded, smells like gas. If i start it by opening the throttle a touch, it starts right up but it isn't warm enough to idle so i have to hold the throttle open. If I try putting on the choke it dies. Any ideas?
fisher1630 is offline
post #2 of 7 (permalink) Old 09-20-2012, 09:26 AM
Does she crank up the second time with no choke on? Mine need choke on the first start of the day and after that none needed unless it sits over night. And after the first start I crank her using little or no added throttle. All these critters develop their little habits for us to learn. And my scoot changes her as the seasons change.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #3 of 7 (permalink) Old 09-20-2012, 09:42 AM
The choke is just a "fuel enricher" and functions the like the throttle....meaning you can pull it back just a little to give the motor a bit more fuel.
So start the semi warm bike with the throttle, but fade the throttle grip off as you roll on a bit of the choke lever to replace it.
You don't need to pull the choke lever all the way back all the time.
post #4 of 7 (permalink) Old 09-20-2012, 10:52 AM Thread Starter
I will give that a try, thanks. Its just odd because I never had that problem before. But it runs great when warmed up at idle, and high RPMs. Just took a 500 miles trip and had no problems other than the odd new starting habits.
post #5 of 7 (permalink) Old 09-20-2012, 11:29 AM
Most starting problems are due to a weak battery. I assume you have a good AGM maintenance free battery in the bike?????
post #6 of 7 (permalink) Old 09-20-2012, 02:25 PM Thread Starter
yeah new agm battery, I will take it out tomorrow and play around with it for a bit and we will see if your method works.
post #7 of 7 (permalink) Old 09-20-2012, 07:38 PM
romeobravo172
romeobravo172's Avatar
New can be faulty! Put a full charge on it and take it to local auto store and have it load tested to be sure. Clean the 2 main ground connections, batt to frame and engine to frame/batt box. Do not just look but like wire brush and clean good, reinstall with a dab of diaelectric grease.
romeobravo172 is offline
