this bike is trying to kill me - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 29 (permalink) Old 09-08-2012, 06:08 PM Thread Starter
i really think black betty wants to commit suicide.
I was ridding along just fine last night around 8:30 me and my girl and the bike was doing great.
We pulled into a chinese joint and got some grub.
took all of 45 mins max to eat and hit the road again.
i hit the u turn jumped on to highway 290 and made my way to the inside lane and thats when it happened.
black betty just shut down i flipped it to prime hoping it was poogs even though i cleaned the whole fuel cap about a month ago but she just wouldnt catch and go i had to look for my escape.
this is one of those lovely highways here in houston that has an hov lane with concrete barriers up instead of an inside shoulder and being that traffic was flowing at about 75 to 80 and i was rapidly loosing speed i couldnt safely coast to the right side shoulder if i had even tried i would be getting scooped off the pavement and thrown in a hefty bag.
so i take the chance and bring her to a stop in the left lane where the hov wall had been pushed in just enough to have my tires on the yellow line there were cars whizzing by no more than 18 inches from my right side running 75 to 80 mph i told my girl as soon as we stopped to get off and get over the wall. and that is what she did she was safe but i was doing my best not to crap my pants then as soon as she crossed the wall i got the bike in neutral hit the starter and she fired right off like she was saying ha ha got you didnt i. so my girl mounted back up and i waited for my chance then i booked it as hard as i could to get off that wall and back into the flow without becoming a pancake on the highway
and old betty ran like a beast the rest of the night not even one sign that there was ever a problem
she has done this before it is always after a warm restart no more than 2 miles into the restart she just shuts down and i have to pull over stop completely and restart her never have to open the tank or put it on prime or anything
could this be float valves sticking closed and not opening again until the bowls are totally empty?
i even ran a full bottle of sea foam in the tank today put 130 miles on her then filled up with 2.7 gallons of gas and while running the tank of foam i stopped and ate lunch then jumped on her and bam she did it again 1.4 miles after the restart then just like last night she ran like a scalded ape afterwards
post #2 of 29 (permalink) Old 09-08-2012, 09:13 PM
Mebbe just haunted......yer close enough to Louisiana to ride into the west end....find a Cajun woman that practices "medicine" (I have a friend there named Laleesh...sends me homemeade andouille all the time...she wants me).
Get the bike "blessed" by either a priest or a real cajun witch.....will help a lot, I guaranteeee....mine was blessed this spring by a biker priest....
post #3 of 29 (permalink) Old 09-08-2012, 11:35 PM Thread Starter
i'm open to anything
post #4 of 29 (permalink) Old 09-09-2012, 01:11 AM
I had a shutdown once, Took me a minute on the side of the road to figure out I had unintentionally flipped the right grip Kill Switch off .....bumped it off while ridin' with my bulky cold weather gloves.
WilliamTech
post #5 of 29 (permalink) Old 09-09-2012, 02:39 AM
The stand switch can cause weird cutting off to happen. You might try some wd and work it some.
post #6 of 29 (permalink) Old 09-09-2012, 02:57 AM
x2 !
post #7 of 29 (permalink) Old 09-09-2012, 03:15 AM
It's possible for the switch to cause that, but only after riding for a while and shutting it off only to have it do it a few miles after starting back up?
I know it would be possible for it to happen right when you put it in gear after you put up the kickstand. If the switch was bad, it looks like to me it would do it before that IMHO.
If the switch was sticky, the bike would die after putting it in gear because the switch would be stuck. Stranger things have happened I suppose.
TSmith68 is offline
post #8 of 29 (permalink) Old 09-09-2012, 03:47 AM
possible
post #9 of 29 (permalink) Old 09-09-2012, 11:25 AM
Gemguy's Avatar
You may also want to check and make sure the fuel tank vent under the gas cap is clear so you are not getting a vacuum in the tank. As mentioned above, the stand switch and kill switch should also be looked at.
~VROC~ # 389
Gemguy is offline
post #10 of 29 (permalink) Old 09-09-2012, 04:04 PM
I had a yammy that would start out fine. Than the vibration would make the stand switch act up and finally shut the engine down.
