Removing and cleaning carb - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 09-04-2012, 12:07 AM Thread Starter
So i need to remove and clean the carb on my 1998 vn750. Doe's anyone have any videos that would show me how to do this step by step. Or can anyone explain it to me. From actually removing it from the bike to cleaning it. I want her to run strong for me again
Jcthoma3 is offline
post #2 of 25 (permalink) Old 09-04-2012, 08:50 AM
Check out the carb re-build videos posted by Roach. They're stickied at the top of the page. I followed these along with the Clymers manual and was able to pull it off with very little trouble. Great videos BTW.
33,000 km's
Yuasa MF Battery
Iridium plugs/new wires & boots.
Custom 900 Seat
Bar end mirrors
Lowered headlight
Carbs cleaned
Gold Phillings is offline
post #3 of 25 (permalink) Old 09-04-2012, 09:27 AM
wrench
Yamamoto's Avatar
I removed mine last weekend, used no manual or video's.
It is not so difficult, just not easy to work due to the small space they are stuffed in.
Cleaning is for next weekend, i searched and looked @ the video's mentioned above and can highly recommend them.
Yamamoto is offline
post #4 of 25 (permalink) Old 09-04-2012, 09:40 AM
Youngster
1stVulcan's Avatar
https://www.vn750.com/forum/showthread.php?t=19660
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
post #5 of 25 (permalink) Old 10-10-2012, 04:26 PM
Send a message via Yahoo to docwest8404
Hey, new to the forum and the VN750. Having the same problem, but rather than bug ya'll, where do I find the "Stickies" with the Roach Video's?
docwest8404 is offline
post #6 of 25 (permalink) Old 10-11-2012, 03:04 AM
wrench
Yamamoto's Avatar
Hey welcome here.
A stickie is a post that is made to be permanent on top of the list in that section.
You can find this 1 here:
There are a number of great video's from Roach, all listed in his signature.
Yamamoto is offline
post #7 of 25 (permalink) Old 10-11-2012, 04:23 PM
Where would be the best place to find a manual, aside from buying a brand new one from Clymer, which i may do anyway. Thanks ahead of time.
post #8 of 25 (permalink) Old 10-11-2012, 04:58 PM
it can be downloaded here:
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
It is a large file, so right click and save it.
post #9 of 25 (permalink) Old 10-12-2012, 11:03 AM
I've pulled my carbs more times than I care to count and I'm only moderately inclined to these matters. I HIGHLY suggest that you ear shave and coaster while the carbs are out so that you can get rid of the big black airbox on top of the carbs. There are tons of threads about this that you can search for. This will make it so much easier to pull them in the future and you will thank yourself for it.
vulcanpower is offline
post #10 of 25 (permalink) Old 10-15-2012, 04:35 PM
What is "ear Shaving" and "Coastering"? I'm a complete Noob when it comes to most of these terms.
Tags
carb , carbs , carburetor
