Carb tubes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-22-2012, 04:23 PM Thread Starter
Carb tubes
I'm trying to figure out where these two tubes attach to on my 99 Vulcan. I was thinking that this first one would attach under the middle of my gas can.
This second one is so short I can't find anything to attach it to. It's on the right side of my bike. Maybe it was just tucked away somewhere as an air tube of some sort?
Thanks in advance for the help and advice!
ID:	4829   Click image for larger version
theidealford is offline
post #2 of 11 (permalink) Old 08-22-2012, 04:38 PM
If your bike is a California model, the gas tank would have 2 vents at the rear. The 1st pic is more than likely the tank vent tube which connects to the rear. As far as I know, nothing connects at the center other than the wiring harness from the fuel gauge sending unit. That other tube looks like the vacuum line for the rear cylinder. It normally goes to the emissions junk at the rear of the engine.
Hope this helps.
post #3 of 11 (permalink) Old 08-22-2012, 05:21 PM Thread Starter
There aren't two vents at the rear... so I don't think it's a California model. Also, the other tube is way too short to connect to anything near the back of the engine... thanks for the input though.
post #4 of 11 (permalink) Old 08-22-2012, 05:45 PM
The line that's on the carb went to an air diverter valve at the rear of the engine.
If the diverter valve is gone from the bike you can take it off and plug that port on the carb, or it's not going to run right, and it will lean out that cylinder and you will get a lot of backfiring.
The other pic is too small for me to make out where it is hooked to, but it looks like a vacuum line of some sort. It looks too small to be a fuel line.
TSmith68 is offline
post #5 of 11 (permalink) Old 08-22-2012, 06:02 PM
use the search function and look up "marbling" or "coaster"
If the valve under the tank is missing just in front of the battery box, then it sounds like the emissions items were partially removed.
The reed valves on the cylinder's might be plugged or replaced with "coasters".
The vacuum hose off the right carb should either be plugged into the valve under the tank (which in turn will have hoses going to each reed valve on the cylinder) or plugged off if the emissions stuff was removed.
post #6 of 11 (permalink) Old 08-22-2012, 06:37 PM Thread Starter
Better view of the first cable. It's attached to the silver thing in front of the battery.
post #7 of 11 (permalink) Old 08-22-2012, 06:38 PM Thread Starter
I attached a better photo a little lower down on the feed.
post #8 of 11 (permalink) Old 08-22-2012, 07:02 PM
I'd suggest upgrading you battery while your at it to a MF model.
As for the vent tube, it's definitely part of the emissions but mines been gone for so long I don't remember where it all hooked up.
post #9 of 11 (permalink) Old 08-22-2012, 07:20 PM Thread Starter
This might be a horrible answer... but vacuum tubes don't get attached to anything correct?
post #10 of 11 (permalink) Old 08-22-2012, 07:31 PM
Yes they do. 1 line works pet cock; the other goes to emission.
